Passat abs-boxi koodaus
Aloittaja Jeegeri, 11.01.24 - klo:18:53
Jeegeri
Onnistuuko joltakin abs-boxi koodin laskeminen, iteltä kun ei oikein onnistu, eikä näytä tähän edes kuvien upottaminen onnistuvan...
0033E8Thursday,11,January,2024,16:56:00:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.11.0.0 (x64)
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WVWZZZ3CZ7E219894   License Plate: ASI269
Mileage: 341900km-212446mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 53 55 56 62 72
VIN: WVWZZZ3CZ7E219894   Mileage: 341900km-212446miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: Redir Fail!
   Part No SW: 06F 906 056 GQ    HW: 06F 906 056 DQ
   Component: MED9.5.10       G00 0460
   Revision: 68H03---    Serial number: VWZCZ000000000
   Coding: 0000172
   Shop #: WSC 00191 264 15243
   VCID: 7EF34BFF29F77C61B1-802A
   VINID: 9E69EAAAA0D3A87542049209101468D0D0
   Subsystem 1 - Component: NOX  0000000000
   NOX  0000000000
3 Faults Found:
005715 - Please check DTC Memory of ABS Controller
               P1653 - 001 -
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 22
                    Reset counter: 255
                    Mileage: 341879 km
                    Time Indication: 0
                    Date: 2023.03.24
                    Time: 23:14:32
             Freeze Frame:
                    RPM: 720 /min
                    Load: 25.9 %
                    Speed: 0.0 km/h
                    Temperature: 67.0°C
               P1653 - 004 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 25
                    Reset counter: 255
                    Mileage: 341879 km
                    Time Indication: 0
                    Date: 2023.03.24
                    Time: 23:14:32
             Freeze Frame:
                    RPM: 720 /min
                    Load: 25.9 %
                    Speed: 0.0 km/h
                    Temperature: 67.0°C
053254 - No Communication with NOx Sensor 1 Bank 1
               U1006 - 008 -  - MIL ON
             Freeze Frame:
                    Fault Status: 11101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 341879 km
                    Time Indication: 0
                    Date: 2023.03.24
                    Time: 23:14:32
             Freeze Frame:
                    RPM: 720 /min
                    Load: 25.9 %
                    Speed: 0.0 km/h
                    Temperature: 67.0°C
Readiness: 0110 0001
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 109     HW: 3C0 614 109
   Component: ESP 440 C4     H018 0001
   Revision:  H018       Serial number: 0775262056
   Coding: 0010000
   Shop #: WSC 11400 205 96003
   VCID: 5BB5226B9A258949F6-800E
4 Faults Found:
01042 - Control Module; Not Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 24
                    Reset counter: 18
                    Mileage: 341879 km
                    Time Indication: 0
                    Date: 2023.03.24
                    Time: 23:21:11
00778 - Steering Angle Sensor (G85)
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 24
                    Reset counter: 18
                    Mileage: 341879 km
                    Time Indication: 0
                    Date: 2023.03.24
                    Time: 23:21:11
01423 - Lateral Acceleration Sensor (G200)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 24
                    Reset counter: 18
                    Mileage: 341879 km
                    Time Indication: 0
                    Date: 2023.03.24
                    Time: 23:21:11
00810 - Sensor 1/2 for Brake Pressure
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 24
                    Reset counter: 18
                    Mileage: 341879 km
                    Time Indication: 0
                    Date: 2023.03.24
                    Time: 23:21:11
Address 08: Auto HVAC        Labels: 3C0-907-044.clb
   Part No SW: 3C0 907 044 BB    HW: 3C0 907 044 BB
   Component: ClimatronicPQ46 112 0606
   Revision: 00112021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 62CB1F8FBD4FB881B5-8036
No fault code found.
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006880713
   Coding: EE8E8F0700041A00470A00000F000000000A5D435C0001
   Shop #: WSC 05311 000 00000
   VCID: 6CD771B74F8BFEF10F-8038
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 120307 003  0205
   Coding: 00046997
   Shop #: WSC 05311
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     020407 020  0105
   Coding: 00208933
   Shop #: WSC 05311
3 Faults Found:
01504 - Bulb for License-Plate Light (X)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 20
                    Mileage: 341879 km
                    Time Indication: 0
                    Date: 2023.03.24
                    Time: 23:21:00
             Freeze Frame:
                        ON
                    Voltage: 14.20 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
02394 - Parking Light Left Front (M1)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 20
                    Mileage: 341879 km
                    Time Indication: 0
                    Date: 2023.03.24
                    Time: 23:21:00
             Freeze Frame:
                        ON
                    Voltage: 14.15 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
02395 - Parking Light Front Right (M3)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 20
                    Mileage: 341879 km
                    Time Indication: 0
                    Date: 2023.03.24
                    Time: 23:21:00
             Freeze Frame:
                        ON
                    Voltage: 14.15 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 3C0-909-605.lbl
   Part No SW: 3C0 909 605 N    HW: 3C0 909 605 N
   Component: 19 AIRBAG VW8R  032 2522
   Revision: 13032000    Serial number: 003B2P59VYVM
   Coding: 0012601
   VCID: 3169A0C3A82953197C-8064
   Subsystem 1 - Serial number: 6332MSME183A7C23H
   Subsystem 2 - Serial number: 6342MSME1776223EE
   Subsystem 3 - Serial number: 6351HTS65JHGO5G6V
   Subsystem 4 - Serial number: 6361HTS6LNF4U7N6A
   Subsystem 5 - Serial number: 00000000000000000
   Subsystem 6 - Serial number: 00000000000000000
1 Fault Found:
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
Address 16: Steering wheel        Labels: 3C0-953-549-SW20.lbl
   Part No SW: 3C0 953 549 M    HW: 3C0 953 549 M
   Component: J0527               0015
   Revision: 00006000    Serial number: 3C9953507AG
   Coding: 0000112
   VCID: 366393DF4147742129-8062
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
Address 17: Instruments        Labels: 3C0-920-xxx-17.lbl
   Part No SW: 3C0 920 870 T    HW: 3C0 920 870 T
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: V0007000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 00011 888 06946
   VCID: 3467A9D7573B663117-8060
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C073270D3A
   Coding: FDFD0C04C22002
   VCID: 21495083F8C9E399EC-8074
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 K
   Component: Haldex 4Motion      1118
   Coding: 0000001
   VCID: 356194D35C417F3920-8060
1 Fault Found:
01316 - ABS Control Module
            013 - Check DTC Memory
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0383
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 7AFB47EF35DF50418D-802E
   Subsystem 1 - Part No: 3C0 905 861 G
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1K0 959 701 P    HW: 1K0 959 793 L
   Component: J386  TUER-SG FT    1131
   Revision: 32008001    Serial number: 00000594078323
   Coding: 0000245
   VCID: 3B7582EB7A65A949D6-806E
1 Fault Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 4
                    Fault Frequency: 254
                    Reset counter: 60
                    Mileage: 341879 km
                    Time Indication: 0
                    Date: 2023.03.24
                    Time: 23:21:10
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.134 H07 1806
   Shop #: WSC 02069 000 90108
Address 46: Central Conv.        Labels:. 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 043 0612
   Coding: 0091020051030E763004941570084F0B607C01
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
1 Fault Found:
00893 - Switch for Trunk Handle (E234)
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 19
                    Mileage: 341879 km
                    Time Indication: 0
                    Date: 2023.03.24
                    Time: 23:21:13
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
   Component: J387  TUER-SG BT    1131
   Revision: 32008001    Serial number: 00000583278311
   Coding: 0000244
   VCID: 3C7781F77F6BAE71DF-8068
1 Fault Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
             Freeze Frame:
                    Fault Priority: 4
                    Reset counter: 60
                    Mileage: 341879 km
                    Time Indication: 0
                    Date: 2023.03.24
                    Time: 23:21:10
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 E    HW: 3C0 907 801 E
   Component: EPB  VC8HC003   013 0003
   Revision:   013
   Coding: 0010000
   VCID: 24475997E7DBF6B187-8070
4 Faults Found:
01087 - Basic Setting Not Performed
            000 - - - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 4
                    Fault Frequency: 11
                    Reset counter: 19
                    Mileage: 341848 km
                    Time Indication: 0
                    Date: 2023.03.17
                    Time: 00:10:19
             Freeze Frame:
                    Voltage: 9.83 V
                    Count: 170
            013 - Check DTC Memory - MIL ON
             Freeze Frame:
                    Fault Status: 11101101
                    Fault Priority: 3
                    Reset counter: 20
                    Mileage: 341848 km
                    Time Indication: 0
                    Date: 2023.03.04
                    Time: 01:18:03
             Freeze Frame:
                    Voltage: 12.94 V
                    Count: 236
02435 - Supply Voltage for Control Module for Right Channel
             Freeze Frame:
                    Fault Status: 11101001
                    Fault Priority: 1
                    Fault Frequency: 15
                    Reset counter: 18
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 9.83 V
                    Count: 113
            000 - - - MIL ON
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 15
                    Reset counter: 18
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 9.94 V
                    Count: 171
Address 55: Headlight Range        Labels: 5M0-907-357-V2.clb
   Part No SW: 5M0 907 357 A    HW: 5M0 907 357 A
   Component: AFS-Steuergeraet    X014
   Revision:   H01       Serial number:
   Coding: 2334721
   VCID: 326BAFCFAD2F680105-8066
   Subsystem 1 - Part No: 7L6 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    X018
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X018
   Coding: 00000035
1 Fault Found:
02235 - Stationary Cornering Lamp (Left) (M51)
            011 - Open Circuit - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 19
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No: 1K0 035 186 T
   Component: Radio GR0       020 0023
   Revision: 0002006S    Serial number: VWZ2Z2G3068374
   Coding: 0040400
   Shop #: WSC 05314 000 00000
   VCID: 377D9EDB464D8D2932-8062
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1119
   Revision: 11006001    Serial number: 00000001512981
   Coding: 0000208
   VCID: 3D718CF36471A779E8-8068
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1119
   Revision: 11006001    Serial number: 00000001525924
   Coding: 0000208
   VCID: 3E738BFF6977BC61F1-806A
End-------------------------(Elapsed Time: 02:00)--------------------------
Mikä mallivuosi? Onko tässä vielä lyhyt koodaus, vai pitkä?
2007 näkyisi olevan ja lyhyt koodaus noissa on. Kannattaisi ehkä etsiä VCDS skannaus mahdollisimman samanlaisista autoista ja kokeilla niitä koodauksia.
Jos ABS koodaus on persiillään, niin EPB menee myös nollille (tuossa Coding: 0010000). No se on helppo korjata VCDS:llä.
Jeegeri
Ei oikein ole löytynyt oikeata koodinpätkää 2.0fsi 4motioniin, tuolta rosstechin sivuilta tai forumiltakaan ei oikein oikeata löytynyt.
Linkin takaa löytyy mallivuoteen 2007 asti olevat ohjeet (jotka koskee short codingia)
LainaaThe latest versions of VCDS come with a Coding Helper (availability may vary) allowing the user to determine the Coding based on Vehicle Equipment using the PR-Codes . In case you are unable to determine the Coding, please contact us directly and we can try to assist registered customers with the Coding Process. Every inquiry on this topic has to include a full Auto-Scan as well as which parts have been replaced and why, also make sure the Auto-Scan includes the complete VIN of the vehicle in question. The Factory Tool will normally perform the Coding by querying Software Version Management (SVM) for the proper Value.
Eikö tuo short codingin ikkuna siis anna mitään ponnahdusikkunoita syötettävän kentän kohdalta joissa on selostettu mikä numero vastaa mitäkin asetusta, tähän malliin?
Jeegeri
Ei ainakaan huomannut että olis antanut mitään apuja, long coding anto pari vaihtoehtoa mutta en mitää niistäkään saanut irti.
Tuossa yksi manuaali, ei 4-veto. 4-vetoon pitää lisätä koodaukseen 128, jos passiivinen renagaspainevahti, niin sitten vielä 2048 lisää.
Address 01: Engine Labels: REDIR FAIL!
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.CLB
Part No SW: 3C0 614 109 AF HW:3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --025--- Serial number: 00000795664609
Coding: 0000362
Tässä toinen:
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 N HW: 3C0 614 109 N
Component: J104 C4 440 V1 0011
Revision: --025--- Serial number: 00000785684425
Coding: 0004454
Tuosta jos vähentää 4096 (multifuel?), niin jäljelle jää 0000358.
Kokeile koodaukset 0000486, 0000488 ja 0000490. Kokeilla voisi myös etuvetojen koodit 0000358, 0000360 ja 0000362.
Googlesta löytyy VCDS Auto-Scan tulosteita, VCDS-foorumilla se on pakko laittaa jos meinaa tukea/apua saada. Esim. https://forums.ross-tech.com/index.php?threads/1033/
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0667540883
Coding: 0046544
Shop #: WSC 00028 028 00001
VCID: 326B0E6EADA4FF8E5D3-8067
https://www.google.com/search?q=passat+3c+2.0fsi+4motion+vcds+code&;
Toki jenkeissä on jenkkivarusteet ja mahdollisesti tuo aktiivinen rengaspainevahti.
Voi *ittu kun joutuu taistelemaan tämän foorumin kanssa, copy-pastessa mikään lainaus ei mene kohtuudella vaan joutuu välilyöntejä poistelemaan yms.
kannattaa tarkistaa myös login-valikko että pitääkö boksille kirjautua erikseen sisään jollain pin-koodilla jotta se hyväksyy noita koodausmuutoksia
Jeegeri
Menee koodaus ihan ilman loginia läpivitse mutta ei noista koodeista mikää oikein tuo toivottua lopputulosta varsinkaan kun nelivetokin hävisi nyt :D, entiedä onko jotain merkitustä kun tossa autossa on Bux moottori ja JXQ manuaali-aski, monet noista koodeista se hyväksyi mutta aina tuli nekivedosta tai väärin koodatusta ohjainlaitteesta vikakoodit.
Kovasti olisi helppoa jos se alkuperäinen koodinpätkä olisi tallessa :D
Lainaus käyttäjältä: Jeegeri - 12.01.24 - klo:15:18Kovasti olisi helppoa jos se alkuperäinen koodinpätkä olisi tallessa :D
Onko Full scannia tehty koskaan samalla VCDS:llä, silloin kun autossa oli vielä edellinen ABS-moduuli? Softahan logittaa nuo /Logs kansioon. Sieltä voisi löytyä oikea koodi. Jos ei muu auta, niin merkkiliikkeessä viimeistään saavat tuon koodattua kuntoon.
Tuossa alkup. viestissä on:
LainaaAddress 22: AWD        Labels: 1K0-907-554.lbl
   Coding: 0000001
1 Fault Found:
Oletko käynyt jo tuolla moduulilla putsaamassa tuon koodin pois, vai onko se häipynyt itsestään?
Onko abs-moduulin koodit nollattu? tuleeko sinne mikään takaisin?
oletko kirjautunut ulos abs-moduulilta tuon koodauksen muutoksen jälkeen ja varmistanut että se on myös tallentunut / pysyy muistissa siellä?
Joskus tuo 19-canväyläohjain pitää myös "päivittää" että se skannaa taas ohjainlaitteet väylältä, eli ajaa shortcodingiin sama arvo mikä siellä on ja vaan tallentaa.
Jeegeri
Auto tuli mulle tollasena joten ei löydy scannia mistä noi näkyisi.
Jos moduli hyväksyy koodauksen niin se näkyy aina siella koodikentässä mutta tulee sitten virheitä nelivedolta tai moottorinohjainlaitteelta.
Kaikki varoitusvalot vilkkuu mittaristossa.
Jacce75
Lainaus käyttäjältä: Jeegeri - 11.01.24 - klo:18:53Onnistuuko joltakin abs-boxi koodin laskeminen, iteltä kun ei oikein onnistu, eikä näytä tähän edes kuvien upottaminen onnistuvan...
Ellei ole paha rasti niin aja Keravalle niin hoidan asian sulle kuntoon. Sovittaessa voin myös tulla käymään auton luona.
http://www.vagtech.fi
040-7049099
keskustelu.vagtech.fi
Jeegeri
Sen verran matkaa ettei siirtokilvillä kannata lähteä keravalle asti.
