Touareg 7P bluetooth koodaus päälle
Aloittaja Gaz, 03.10.18 - klo:09:06
Gaz
Minulla on 2011 Touareg ja vehkeessä ei ole puhelintukea tällä hetkellä.
Tältä ja muutamalta muultakin foorumilta on löytynyt tieto että puheohjattavissa autoissa bluetoothin toimintamaan saattaminen on onnistunut pelkällä koodauksella. Maininta mm. tässä ketjussa: http://www.vagarena.fi/index.php?topic=31430.msg559747#msg559747
Kaytössä olisi VCDS, mutta koodausohjeita ei ole tullut vielä vastaan. Onko aihe tuttu kenellekään?
Gaz
Lisägooglettelu alkaa tuottamaan tulosta:
https://www.mytreg.com/index.php?/topic/8325-t3-vagcom-tweaks/page__view__findpost__p__525329
Joku suomalainen (Juha niminen) vahvistaa että vielä 2016 vuonna tuo on toiminut.
Lainaa
LainaaView Postreckless, on 23 January 2011 - 08:01 PM, said:
Hello, guys!
It's me who wrote that post (first one in this thread) on clubtouareg.com. Unfortunately that forum seems to be dead. Anyway, I'd like to share found information, so here I am.
There's one more VAGCom trick, which is possible on new Treg - you may add Bluetooth to any RNS850 without any money. The microphone and other hardware is factory installed, all you need - is to enable it! this info is widely spread on Audi forums, but I was the first who found it in Treg3. So:
1 use VAGcom and enable Hidden (also called green) menu in RNS by setting 1 in channel 6, module 5F
2 press Car + Setup simultaneously for several seconds and enter Hidden menu. go to diagnose, then settings by rotating and pressing central knob and select AUX/AMI BT/AMI instead of AUX/no AMI BT/AMI (or find another variant without "no AMI BT")
3 also change Tel Settings misc (See diag spec) to 3. dont ask me what is it
4 reboot RNS device by simulteniously pressing Phone + Climate + Nav + Traffic + Central Knob. The other way to reboot it is to plug out fuse 47 on the right side of dasboard (am i right, is everything in front of you really called dashboard?). Another way is to leave the car closed for a night - it's enough time to self-shutdown RNS
5 set 1 to channel 17, module 5F by VAGCom. it can't be done before reboot, as channel will be unreadable.
Now you may press Tel button and connect your phone. the bluetooth is almost the same as factory one
Sorry for my english, sometimes it's not so perfect
Hi,
As a newbie, I can confirm this to work perfectly! Thanks a million for this.
I have a 2011 Treg 3.0tdi with rns850 & no factory BT. I followed these steps, and now the BT works. Magnificient!
I also coded back DRLs to work, but had no luck in disabling Start-Stop...
Rgds,
-Juha
Gaz
Ja voin vahvistaa että bluetooth meni päälle yllä olevilla ohjeilla omasta autosta.
mrjj
Samoin. Ja muista myös eberin esilämmitys !
VW T5GP 2012
Alhambra / Sharan 2012
Touareg 2011
