Audi A8/S8
Aloittaja Flat, 01.12.09 - klo:07:37
Audi A8 viralliset kuvat
Autocar.co.uk:
LainaaThe new Audi A8 has just been launched in Miami, ahead of its arrival in UK showrooms next March.
The new car has lost the mass and bulk of the current model’s styling, replacing it instead with design themes from the A4. Much of the A8’s exterior design is lifted from the A4, especially around the front and rear.
Hi-res pictures of the new Audi A8
Audi A8: Rupert Stadler Q+A
It’s a bigger car than its predecessor and at 5137mm long, 1949mm wide and 1460mm tall, it’s longer and wider than a Mercedes S-class or a BMW 7-series but lower than both. That makes it the biggest car in its class.
As with all previous A8s, the car is built from aluminium, and using new alloys has cut 6.5kg from the A8’s weight.
The front and rear lights use LEDs that offer illumination more like daylight than conventional headlamps. They also use less energy and weigh less.
When it’s launched, there will be two engines available, both V8s - the 4.2 FSI petrol with 372hp/328lb ft and the 4.2 TDI diesel with 350hp/590lb ft. The petrol V8 enables the A8 to reach 62mph in 5.7sec while the diesel is actually quicker " 0-62mph in 5.5sec.
A 3.0-litre V6 diesel with 250hp will be added to the range later next year, along with a 204hp version " Audi claims 159g/km for that model.
All A8s come with an eight-speed auto and Quattro four-wheel drive as standard, and there’s a sport differential option which splits torque between the rear wheels. Air suspension is
Audi has added a new safety system called pre-sense, which activates the hazard lights, closes the windows and sunroof and pre-tensions the seat belts if the brakes are fully applied.
There are three other versions of pre-sense available " one which will decelerate the car and apply the brakes, one which will apply the brakes sooner and harder and one which will shift the front seats forward to help protect the passengers in a rear-end collision.
Inside there’s an all-new interior. The gear selector is now an electronic shifter, with four positions; Audi says it’s shaped like the thrust lever on a powerboat. The MMI system has been moved from the centre console to the fascia, and now features a touchpad panel, which allows you to write letters or numbers on the screen to enter phone numbers or navigation destinations.
Come back later for more pictures of the new Audi A8 and comment from the unveil in Florida.
Aivan loistavia (ja paljon)ja kuvia täältä
http://www.autoblog.com/gallery/2011-audi-a8
LainaaThe Audi A8 is not only the most sporty luxury sedan, but also a big gadget. Read on why!
   First, let’s start with the creature comforts.
   * Heated, cooled, and massaging seats
   * Standard 12-way adjustable seats or optional 22-way adjustable optional seats
   * Vibration-canceling motor in the steering wheel
   * Interior LED ambient lighting system
   * Four climate zones
   Entertainment system
   * Standard 14 speaker Bose system or optional 1,400 Watt, 19 speaker Bang & Olufsen system
   * Google maps-enabled GPS system with handwriting input mode
   * 8-inch LCD info screen
   * 20GB hard drive
   * WiFi, USB, and AUX-inputs
   * Dual 10.2-inch rear seat displays with its own DVD player, 20GB hard drive, and controls
   * WLAN via UMTS that turns the car into a mobile HotSpot
   Safety equipment
   * Night vision
   * R8-style LED headlights
   * Adaptive cruise control
   * Radar that detect collisions that automatically tight seat belts and adjusts seats
   * Speed limit camera that actually reads roadside signs and displays them as graphics on the dash
Oikea S8 bongattu....
4.0 TFSI...550 heppaa, nam
Siirsin auton tänne, autohan on jo lähes kaupoissa, joten keskustelu jatkukoon täällä, missä sen kuuluukin olla, lajitoveriensa parissa.
Mielenkiintoinen detalji:  A8 saa google maps yhteyden
LainaaWhen the next-generation Audi A8 launches in 2010, the car’s MMI navigation system will feature the first in-car connection to Google Maps. With the connection, drivers will be able to search for points of interest like “deli” or “movie theater” and get directions to the nearest such locations. You can also choose destinations online via Google Maps or a special Audi website, and then retrieve them from the car’s navigation system.
Later in the year, the MMI system will also be able to stream real-time imagery from Google Earth. That means drivers can see 3D aerial photos on the A8’s navigation screen. Streets and directions will be overlaid on the Google Earth images. The map data is downloaded over cell phones connected to the navigation system with Bluetooth.
In other Audi news, the company has announced that pop star Justin Timberlake will serve as brand ambassador to help spread the word about the upcoming Audi A1. JT will apparently be at the heart of an online marketing campaign starting this spring.
Lähde:http://blog.caranddriver.com/2011-audi-a8-will-feature-google-maps-connectivity/?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+c
Antinontoxic
Audilla ollu taas kopiokone kuumana  :o
ma1ja
Joku kyylä on tällaisiakin nähnyt.
Niin se vaan menee.
LainaaThe new Audi S8 will receive a 620 bhp V10 engine derived from Lamborghini. Awesome!
So how powerful will the new Audi S8 be? Insiders say that the 5.2L V10 will follow the RS6’s forced-induction recipe with direct-injection and twin turbos that will help produce around 620-hp with a maximum torque of 553 lb-ft. That’s significantly up from the old S8’s 444-hp and 398 lb-ft.
ma1ja
Luemme Flatin kanssa ilmeisesti samoja sivustoja  :)
S8 esitellään ilmeisesti vuoden lopussa tai ensi vuoden alussa. Ja myyntiin tulee vuoden päästä, paitsi Suomessa tietenkin joskus paljon myöhemmin.
http://www.autoblog.com/2010/04/14/next-gen-audi-s8-may-boast-620-hp-from-lambo-derived-v10/
Niin se vaan menee.
slash
Tietäsikö joku josta voisin löytää A8:n edellisen mallin (-09 asti) esitteitä / teknisiä tietoja sähköisessä muodossa.
Eikös niitä vielä ihan liikkestä saa, siis paperiversiota?
slash
Niinhän sitä luulisi, mutta ei ainakaan jyväskylästä kun eivät saa myydä edes ko. mallia.
Tässä yksi vaihtoehto jos haluaa esitteestä vähän maksaa.
http://cgi.ebay.de/Audi-A8-Prospekt-Broschuere-August-2008_W0QQitemZ310213708130QQcmdZViewItemQQptZKataloge_Prospekte?hash=item483a2d8962
Esitteitä kannattaisi varmaan kysyä Hertoniemestä tai maahantuojalta.
slash
^Taitaa A8 kotiutua ennenkuin esitteet kerkeisivät postilla tulla.
Aika nihkeästi löytyy tietoa A8:sta nopeasti tsekattuna mm. lisävarusteluetteloa ei löydy edes Audin sivuilta.
Lainaus käyttäjältä: slash - 16.04.10 - klo:20:02
Oletko ostanut A8:n ?
Kerro ihmeessä lisää.
slash
#12
No en per... vaan vaimo on järjestellyt jotenkin työpaikaltaan pomonsa ex. auton itselleen.
Nyt auto pakka menikin vasta sekaisin, olis nyt sit 2 autoa laitettava myyntiin, sen siitä saa kun ei ole kotona vahtimassa rouvan tekemisiä.
wtf
Uudessa A8:ssa mielenkiintoisia toimintoja joissa käytetään GPS paikannustietoja.
Muunmuassa 8-vaihteinen Tiptronic vaihteisto osaa ennakoida tulossa olevan mutkan, jolloin ei vaihda turhaa isompaa pykälää. Sekä ajovalot jotka sopeuttavat valokuvion edessä olevan tiestön mukaan, esim vuoristossa tulossa olevaan ylämäkeen käännetään valoja ylöspäin tai kun olet motarin kiihdytyskaistalla valokuvio muuttuu valmiiksi nopeaan ajoon sopivaksi.
Ai turhia toimintoja? Tulevaisuutta.
Mitä mitä ! Onko slashilla A8?
Tänään tuli juuri espoon merituulen pihassa zoomailtua S8:sia. Kelpo peli.....
Lainaus käyttäjältä: slash - 16.04.10 - klo:20:11
No per... tosiaan...  Mitäs A4:n tilalle on harkinnassa?
Lainaus käyttäjältä: Flat - 16.04.10 - klo:20:41
Mitämitä Merituulessako? Volkkaricenterissäkö? Miksi niitä siellä oli ? Vai olitko Audicenterissä?
LainaaMitämitä Merituulessako? Volkkaricenterissäkö? Miksi niitä siellä oli ? Vai olitko Audicenterissä?
ei kun sen hotelli merituulen pihassa
audicentterissä piti käydä kotimatkalla, mutta ajatuksissani ajoin ohi ja en jaksanut kääntyä....
slash
Lainaus käyttäjältä: Pertsa - 16.04.10 - klo:21:10
Varmaankin polkupyörä... katsotaan ny miten tää homma alkaa järjestyy, tuli aika puskista tää A8 juttu. S5 vois olla kiva tuontiauto jos sais nää muut myytyä ympäriltä pois.
VWonderman
#19
Lainaus käyttäjältä: Flat - 16.04.10 - klo:21:14
Höh, jos ois Merituules ollu ni oisin menny tsekkaa.  ;)
Lainaus käyttäjältä: slash - 16.04.10 - klo:21:17
Hyvähyvä!  :D
(•_•)
Postissa putkahti tänää  muhkea audi magazine ja siellä oli juttua a8:sin valaistuksesta.
Onpa hienot systeemit sisällä, tunnelmavalot joiden värisävyä voi säätää aina punaisesta kirkkaanvalkoiseen....upeita kuvia lehdessä sisävalaistuksesta!
Lisäksi ajovaloista iso juttu, ajovaloissa 7 eri toimintoa kuvasarjalla selitettynä.
puolihop
Ensimmäinen uusi A8 bongattu Vantaalla. oli Koe/väliaikaisrekkarissa, väriltään musta ja takana luki TDI Quattro.
Hieno oli luonnossa.
DrPepper
Lainaakiinalasten A8L
No ei. A8L, toisin kuin A6L ja A4L jotka tosiaan ovat Audilla Kiina exclusive, on kansainvälinen malli jolla on suuret markkinat myös Euroopassa ja Yhdysvalloissa. Suomessakin myydään joku kymmenen vuodessa.
DrPepper
LainaaJoku kyylä on tällaisiakin nähnyt.
Kuvassa on muuten harvemmin nähty malli, A8 Security (ei S8 kuten ensin arveltiin). Jos tarvitsee vältellä rynnäkkökivääreiden luoteja työkseen. Olemassa on myös hieman kevyemmin armoroitu A6 Security katurosvojen varalle.
DrPepper
LainaaEnsimmäinen uusi A8 bongattu Vantaalla. oli Koe/väliaikaisrekkarissa, väriltään musta ja takana luki TDI Quattro.
Olikohan kyseessä ensimmäinen Suomeen tuotu, A8 4.2 TDI quattro tiptronic Havanna-mustalla metallivärillä, ruskeanahkaisella 20 000 euron Audi design selection balao brown -varustepakettilla ja koko lailla melkein kaikilla muilla herkuilla. Sellainen auto oli kuulemma ollut ensiesittelyssä Helsingissä kuukauden alussa.
kokken
13.4 oli tampereen audi-centerin pihassa uusi A8, metallihopea ja muistaakseni ilman mallimerkintöjä. Auto oli uskomattoman arkisen näköinen, mutta todella pisti silmään pyöräkoteloiden valtava koko, renkaiden yläpuolella oli varmaan sellainen 10-12 senttiä tyhjää ja vaikutelma aivan tökerö.  Kuvitelkaa huonontien alusta ja tuplatkaa se? Autossa oli kuitenkin aluvanteet, ei vaikuttanut miltään tilapäiseltä rengastukselta. Toisaalta sisustassa oli vielä suojamuovit ja lasinpyyhkijöinä sellaiset vihreät tynkäsulat. Olisin ottanut kuvan jos olisin tiennyt että ollaan näin niukkojen havaintojen varassa, mutta ei ole tullut seurattua tätä ketjua.
DrPepper
LainaaKuvitelkaa huonontien alusta ja tuplatkaa se? Autossa oli kuitenkin aluvanteet, ei vaikuttanut miltään tilapäiseltä rengastukselta. Toisaalta sisustassa oli vielä suojamuovit ja lasinpyyhkijöinä sellaiset vihreät tynkäsulat.
Rengastus ei ollu tilapäinen, mutta autossa oli joko kuljetuksen aikaiset korotuspalikat tai ilmajousitus oli lift-tilassa - tai molempia.
RoccoScientist
Kävin tänään piipahtamassa Flamingon Audi-Centerissä ja siellä olisi nyt halukkaille pällisteltävänä uusi ja kiiltävä A8. En rohjennut istua sisälle, mutta sisätilat näyttivät luonnossa varsin mukavilta. Ulkopuolelta tuo on aika geneerisen näköinen, mutta se ei varmaan asiakaskuntaa hirveästi häiritse.
Ktk
Parin tunnin päästä on uusi kasi Espoossa piipahtamassa iltaan asti. Istuakkin saa jos huvittaa...
