väylävika vai ?
Aloittaja Jari2passat, 19.08.25 - klo:18:23
Jari2passat
auto toimii normaalisti, mutta vikakoodeja on pitkä rivi, muuta ei ole havaittavissa kun ohjaulukko ei reagoi mitenkään.. missähän on syy
vikakoodit:
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (   )       Labels:. 06J-907-115-BZB.clb
Part No SW: 06J 906 026     HW: 06J 906 026
Component: MED17.5             6974
Revision: A8H03---    Serial number: VWZCZ000000000
Coding: 0404000318070160
Shop #: WSC 11200 205 86341
VCID: 67DD0E9B566DDDBCA2-8032
17 Faults Found:
049493 - No Communication with Instrument Cluster
U0155 - 000 Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 49
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 99.0 C
Temperature: 64.0 C
Absolute Pres.: 1010.0 mbar
Voltage: 12.446 V
049682 - Steering Column Control Module
U0212 - 000 - No Communications - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 49
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 99.0 C
Temperature: 64.0 C
Voltage: 12.446 V
049508 - No Communications with HVAC Control Module (J301)
U0164 - 000 -  - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 248
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 99.0 C
Temperature: 64.0 C
Voltage: 12.319 V
049478 - No Communication with Diagnostic Gateway
U0146 - 000 -  - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 99.0 C
Temperature: 64.0 C
Voltage: 12.319 V
008852 - Fuel Pressure Regulator Valve (N276)
P2294 - 000 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 87.0 C
Temperature: 45.0 C
Voltage: 12.192 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 000 - Supply Voltage - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 72.0 C
Temperature: 34.0 C
Absolute Pres.: 990.0 mbar
Voltage: 12.065 V
049441 - No Communication with ABS Brake Control Module
U0121 - 000 -  - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 53.0 C
Temperature: 30.0 C
Voltage: 11.938 V
049448 - No Communications with Parking Brake Control Module
U0128 - 000 -  - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 53.0 C
Temperature: 30.0 C
Voltage: 11.938 V
049489 - No Communications with Airbag Control Module
U0151 - 000 -  - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 761 /min
Load: 20.4 %
Speed: 0.0 km/h
Temperature: 90.0 C
Temperature: 41.0 C
Voltage: 13.843 V
006423 - Relay for Coolant After-Run (J151)
P1917 - 000 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 84.0 C
Temperature: 35.0 C
Voltage: 12.319 V
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 000 -  - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 53.0 C
Temperature: 30.0 C
Voltage: 11.938 V
005633 - Relay for Supply Voltage Terminal 30 (J317)
P1601 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 10.0 C
Temperature: 12.0 C
Voltage: 11.049 V
001378 - System Voltage
P0562 - 000 - Too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 17.0 C
Temperature: 20.0 C
Absolute Pres.: 1000.0 mbar
Voltage: 8.763 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 -  - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 991 /min
Load: 36.8 %
Speed: 0.0 km/h
Temperature: 16.0 C
Temperature: 18.0 C
Voltage: 14.224 V
000772 - Cylinder 4
P0304 - 000 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 990 /min
Load: 21.2 %
Speed: 1.0 km/h
Temperature: 26.0 C
Temperature: 18.0 C
Voltage: 14.351 V
006481 - Radiator Fan 2 (V177)
P1951 - 000 - Movement Restricted / Jammed - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 63.0 C
Temperature: 27.0 C
Voltage: 12.700 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 1578 /min
Load: 35.7 %
Speed: 14.0 km/h
Temperature: 66.0 C
Temperature: -3.0 C
Voltage: 13.589 V
Readiness: 0000 0001
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 C    HW: 3C0 614 109 C
Component: J104    C4 440 V1   0003
Revision: --020---    Serial number: 00000776298792
Coding: 0000309
Shop #: WSC 05311 000 00000
VCID: 1E336B7FC9B7DC7411-804A
1 Fault Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 CK    HW: 3C0 907 044 CK
Component: ClimatronicPQ46 132 0809
Revision: 00132022    Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6CD771B74F8BFEE4CF-8038
2 Faults Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01110010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Mileage: 359365 km
Time Indication: 0
Date: 2024.09.28
Time: 00:05:49
01592 - Air Quality Sensor (G238)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Mileage: 359365 km
Time Indication: 0
Date: 2024.09.28
Time: 00:05:49
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
Component: Bordnetz-SG     H54 2202
Revision: 00H54000    Serial number: 01000007702233
Coding: 088E8F0700041A00470A00000F000000000859435C000100000000000000
Shop #: WSC 05124 000 00000
VCID: 71E960C368A9130CFC-8024
Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
Component: Wischer 220907 003  0205
Coding: 00046997
Shop #: WSC 05124
No fault code found.
Address 15: Airbags        Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
Component: J234__002 VW10 HI   1815
Revision: 19013000    Serial number: 0039DPN9GGJ4
Coding: 0012338
VCID: 3B7582EB7A65A95C16-806E
Subsystem 1 - Serial number: 6333FTS613102897
Subsystem 2 - Serial number: 6343FTS674042847
Subsystem 3 - Serial number: 6353ETS6GERCV2KH
Subsystem 4 - Serial number: 6363ETS62GPBV2KH
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel        Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 AE    HW: 3C0 953 549 AE
Component: J0527               0020
Revision: 00026000    Serial number: 3C9953507AT
Coding: 0000112
Shop #: WSC 05311 000 00000VCID: 6FED66BB7E9D05FCEA-803ASubsystem 1 - Part No: XXXXXXXXXXX
Component: E0221           002 0010
Address 17: Instruments        Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 D    HW: 3C0 920 871 D
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000    Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 80093 222 69422
VCID: 25414493ECE10FAC50-8070
No fault code found
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E    HW: 3C0 907 951
Component: J533__Gateway   H10 0080
Revision:   H10       Serial number: 1200P07A221194
Coding: F9807F460002022002
VCID: 23455A8BE2D5F19C3E-8076
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
Component:    IMMO         042 0383
Revision: 00042000    Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2096057
VCID: 397998E370599B4C04-806C
Subsystem 1 - Component: ELV No Answe ELV No Answer
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 P    HW: 1K0 959 793 L
Component: J386  TUER-SG FT    1131
Revision: 32008001    Serial number: 00000052179027
Coding: 0000181
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
mileage: 359365 km
Time Indication: 0
Date: 2024.09.28
Time: 00:05:48
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.133 H08 1901
Shop #: WSC 02069 000 90108
VCID: 356194D35C417F2CE0-8060
1 Fault Found:
            000 - -
address 46: Central Conv.        Labels:. 3C0-959-433-46.clb
Component:    KSG PQ46 ELV 042 0472
Coding: 0091020051030E763004941570084F0B607C00
Shop #: WSC 00137 211 56823
Subsystem 1 - Component:   Sounder n.mounted
Subsystem 2 - Component:       NGS n.mounted
Subsystem 3 - Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
Component: J387  TUER-SG BT    1131
Revision: 32008001    Serial number: 00000114679026
Coding: 0000180
VCID: 3C7781F77F6BAE641F-8068
Address 53: Parking Brake        Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
Component: J540 EPB3  VW-09393 0009
Revision:   008       Serial number: 00000000223080
Coding: 0010000
VCID: 295948A380F92BCC74-807C
4 Faults Found:
01087 - Basic Setting Not Performed
000 - - - MIL ON
Freeze Frame:
Fault Status: 11110000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 41
Mileage: 352752 km
Time Indication: 0
Date: 2023.10.30
Time: 09:25:21
Freeze Frame:
Voltage: 9.40 V
Count: 43
speed: 0.0 km/h
Hex Value: 0x1250
Hex Value: 0x0001
Hex Value: 0x0101
03190 - Incorrect Vehicle Type
000 - - - MIL ON
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 20
Mileage: 359365 km
Time Indication: 0
Date: 2024.09.28
Time: 00:05:49
Freeze Frame:
Voltage: 13.60 V
Count: 98
Speed: 0.0 km/h
Hex Value: 0x1240
Hex Value: 0x0001
Hex Value: 0x0101
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 232
Mileage: 351221 km
Time Indication: 0
Date: 2023.10.17
Time: 00:01:23
Freeze Frame:
Voltage: 11.10 V
Count: 100
Speed: 0.0 km/h
Hex Value: 0x1250
Hex Value: 0x0001
Hex Value: 0x0101
01279 - Longitudinal Acceleration Sensor (G251)
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11110101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 232
Mileage: 351221 km
Time Indication: 0
Date: 2023.10.17
Time: 00:01:23
Freeze Frame:
Voltage: 11.10 V
Count: 101
Speed: 0.0 km/h
Hex Value: 0x1250
Hex Value: 0x0001
Hex Value: 0x0101
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 AD
Component: Radio GR0       034 0033
Revision: 0003404S    Serial number: VWZ2Z2G3837870
Coding: 0040400
Shop #: WSC 05314 000 00000
VCID: 68DF0DA75B73D2C4AB-803C
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
Component: J388   TUER-SG HL   0304
Revision: 41004101    Serial number: 00000000014625
Coding: 0000144
VCID: 70EF65C763A31A04F3-8024
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
Component: Anhaenger     H09 0100
Revision: 3A001001    Serial number: 00000164379545
Coding: 0100000000000000
VCID: 306FA5C763235A04B3-8064
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
Component: J389   TUER-SG HR   0304
Revision: 41004101    Serial number: 00000000011953
Coding: 0000144
End
Jacce75
Viallinen ohjauslukko saattaa aiheuttaa mitä vaan ongelmia. Kannattaa vaihtaa se vielä kun on auki. Lukkiintuneena on huomattavasti enemmän haasteita saada irti.
http://www.vagtech.fi
040-7049099
keskustelu.vagtech.fi
Jari2passat
Ohjaulukolle ei tule virta (2 paksuinta johtoa ojaulukon liittimessä)
Bensa b6 1.8tsi 07
