A4 (8K) Oven ohjausyksikön kytkennät
Aloittaja Late, 20.04.11 - klo:16:59
Late
Kuljettajan puolen ovi (J386) Matkustajan puolen ovi (J387) Vasen takaovi (J388) Oikea takaovi (J389) kytkennät:
Kuljettajan oven ohjainyksikkö: -J386
Liitin A (6-pin)
Pin 1: Earth for Hall sender
Pin 2: Hall sender signal
Pin 3: Window lifter motor (down)
Pin 4: Hall sender supply
Pin 6: Window lifter motor (up)
Liitin B (20-pin)
Pin 1: CL keyswitch
Pin 5: Rotary latch
Pin 6: Status safe/locked
Pin 7: CL terminal 31
Pin 8: Mirror dip signal 1
Pin 9: Child lock motor (active)
Pin 10: LIN bus
Pin 11: CL/Safe motor (+lock/+de-safe)
Pin 12: Safe motor (+safe)
Pin 13: CL motor (+lock)
Pin 14: CAN L
Pin 15: CAN H
Pin 16: Emergency off hardware wire for seat memory control unit
Pin 17: Mirror dip signal 2
Pin 18: CL terminal 30
Pin 19: Window lifter terminal 30
Pin 20: Terminal 31
Liitin C (16-pin)
Pin 1: Mirror exterior light
Pin 2: Mirror dip signal 1
Pin 3: Mirror terminal 31 power
Pin 4: Mirror terminal 31 potentiometer
Pin 5: Mirror adjustment motor X/Y
Pin 6: Mirror dip signal 2
Pin 7: Mirror adjustment motor X
Pin 8: Mirror adjustment motor Y
Pin 9: Mirror folding motor +
Pin 10: Mirror folding motor -
Pin 11: Mirror indicators
Pin 13: Status position X
Pin 14: Potentiometer supply
Pin 15: Mirror heater
Pin 16: Status position Y
Liitin D (32-pin)
Pin 1: CL Safe LED driver
Pin 2: Emergency-off button memory
Pin 3: Interior door handle illumination
Pin 4: Switch/stowage compartment illumination
Pin 5: Terminal 31
Pin 7: Supply memory keypad
Pin 8: Exit/warning lamp
Pin 9: Status LED tilt sensor button
Pin 10: Status LED interior monitor button
Pin 11: Status LED child lock right
Pin 12: Status LED child lock left
Pin 13: Status LED lock
Pin 14: Emergency off hardware wire for seat memory control unit
Pin 15: Memory button
Pin 16: Exit warning light
Pin 17: Status LED memory button
Pin 19: Position buttons
Pin 20: Interior monitor button
Pin 21: Tilt sensor button
Pin 22: Tank cap release switch
Pin 23: Tailgate remote release button
Pin 24: Mirror adjustment
Pin 25: Mirror selection/folding
Pin 27: Child lock button, left/right
Pin 28: Lock/Unlock button
Pin 29: Rear right window lifter button
Pin 30: Rear left window lifter button
Pin 31: Front right window lifter button
Pin 32: Window lifter button (local)
Matkustajan oven ohjainyksikkö -J387
Liitin A (6-pin)
Liitin B (20-pin)
Pin 5: Rotary latch
Pin 10: LIN bus
Pin 14: CAN L
Pin 15: CAN H
Pin 20: Terminal 31
Liitin C (16-pin)
Liitin D (32-pin)
Pin 5: Terminal 31
Pin 13: Front passenger status LED lock
Pin 17: Front passenger status LED memory button
Liitins, oven ohjainyksikkö, taka vasen/oikea -J388/-J389
Liitin A (6-pin)
Liitin B (20-pin)
Pin 1: Automatic belt return (A5 Cabrio); door exterior handle illumination (exterior lighting)
Pin 2: Door exterior handle switch
Pin 3: CL button in door exterior handle
Pin 4: Child lock status
Pin 5: Door contact switch
Pin 7: CL terminal 31; power latch motor
Pin 8: Automatic belt position (A5 Cabrio)
Pin 10: LIN bus
Pin 16: Return stop contact (power latch)
Pin 17: Catch contact (power latch)
Pin 20: Terminal 31
Liitin C (16-pin)
Pin 1: Interior door handle illumination
Pin 2: Switch/stowage compartment illumination
Pin 3: Ambient lighting
Pin 5: Panorama roof (glass)
Pin 6: Panorama roof (roller blind)
Pin 7: Rear roller blind
Pin 8: Window lifter button opposite
Pin 9: Window lifter button (local)
Pin 10: Lock button (interior locking button)
Pin 11: Status LED Lock
Pin 12: Door exit/warning lamp
Pin 13: Terminal 31
Pin 14: Rear memory button
Pin 15: Rear memory button - Relax/Business position
Pin 16: Status LED for memory
Liitin D (6-pin) (Max+) for rear roller blind
Pin 3: Side roller blind motor (down)
Pin 6: Side roller blind motor (up)
