b8 lämmitin
Aloittaja Stevicon, 30.10.18 - klo:20:09
Stevicon
Tuesday,30,October,2018,20:03:37:47513
VCDS Version: Release 18.2.1 (x64) Running on Windows 10 x64
www.Ross-Tech.com
                Address 18: Aux. Heat       Labels: 8R0-265-105.CLB
Control Module Part Number: 4H0 265 105     HW: 4H0 265 105
  Component and/or Version: Standheizung  H26 0270
           Software Coding: 4D0000
            Work Shop Code: WSC 00001 000 00000
                      VCID: 5F9B5E11E736056F28E-800A
3 Faults Found:
02084 - Component Protection
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Status: 01100101
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
             Freeze Frame:
                    Temperature: 19.0°C
                    Temperature: 143.0°C
                    Voltage: 11.90 V
                        OFF
                    Count: 0
                    Temperature: -50.0°C
                    RPM: 0 /min
                        No
02095 - Component Protection Active
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 235086 km
                    Time Indication: 0
                    Date: 2018.10.30
                    Time: 19:46:40
             Freeze Frame:
                    Temperature: 35.0°C
                    Temperature: 65.0°C
                    Voltage: 11.60 V
                        OFF
                    Count: 0
                    Temperature: 2.0°C
                    RPM: 0 /min
                        No
01042 - Control Module; Not Coded
            000 -  -
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 69
                    Mileage: 235086 km
                    Time Indication: 0
                    Date: 2018.10.30
                    Time: 19:46:41
             Freeze Frame:
                    Temperature: 35.0°C
                    Temperature: 65.0°C
                    Voltage: 11.60 V
                        OFF
                    Count: 0
                    Temperature: 2.0°C
                    RPM: 0 /min
                        No
...vastasin tuonne alkuperäiseen aiheeseen... http://www.vagarena.fi/index.php?topic=40892
