EOS 2009 2.0 TFSI
Aloittaja mikakorh, 15.03.15 - klo:20:03
mikakorh
EOS 2009 2.0 TFSI DSG
240hp/350Nm
WP_20150313_17_43_35_Pro (2) by mika_korhonen, on Flickr
Varusteet
0AE   L   STV   Front stabilizer
0BE   L   STH   Rear stabilizer
0ES   L   EDF   Installation differentiation for transmission DQ250 vehicle components
0FA   L   FAD   Standard manufacturing sequence
0GG   L   AGM   Emission standard EU4
0NB   L   SZU   Nameplate set in base trim
0P6   L   AER   Rear exhaust tailpipe
0TD   P   ZFM   Front and rear floor mats
0XS   E   BTA   Information kit in Latvian
0Y3   L   KLZ   Cold zones
0YB   L   GKH   Weight range 2 installation control only, no requirement forecast
1A5   L   KRS   Fuel system for SI engine (FSI)
1AT   L   BRS   Electronic stabilization program (ESP)
1CT   L   AED   Vehicle class differentiation 1Q0
1D0   L   AHV   Without trailer hitch
1EX   L   TYP   Special identification plate for EC
1G9   E   RER   Space-saving spare wheel for temporary use, radial tire (5-hole)
1JA   L   DFH   Rear shock absorption, basic design 1
1KZ   L   BAH   Disc brakes, rear
1LJ   L   BAV   Disc brakes, front
1N3   L   LEN   Speed-related variable steering assist (Servotronic)
1NT   P   RAA   Wheel center cover
1PC   L   ABR   Wheel bolts with anti-theft protection (unlockable)
1Q1   L   TGL   Mass damper for steering wheel, 26.5Hz
1S1   L   BOW   Tool kit and jack
1SA   L   TWU   Without additional engine guard
1T2   E   VBK   Warning triangle
1Z0   L   KRM   Initial standard fuel filling
2G7   L   EBB   Filler neck module 1 with insert
2KW   L   SAU   Labels/plates in German, French, and Dutch
2LD   L   KRB   Fuel tank without differentiation of special material treatment (fluorination/co-extrusion)
2UA   L   SWP   Standard design
2WA   L   ZBR   Without additional tires
2ZB   P   LRA   Leather multi-function steering wheel
3B4   L   ZKV   Child seat anchor for child seat system ISOFIX
3FE   L   DEI   Electric slide/tilt sunroof with sun screen/sunblind
3G0   L   KSI   Without child seat anchor front (ISOFIX)
3J1   L   KOV   Height-adjustable headrests for front seats
3K0   L   SKS   Without safety headrest system
3LJ   P   TSV   Door and side trim panel in foam film, insert in leatherette
3ND   L   HIS   Rear seat bench/backrest, unfolding
3P1   L   HAL   Bracket for first aid kit and warning triangle
3PB   P   SIE   Left seat with electric seat adjustment,right seat manually height-adjustable
3QC   L   RSV   3-point seat belts, front
3SG   L   SFR   Sports comfort seats front, right
3TG   L   SFL   Sports comfort seats front, left
3X2   L   DLS   Load-through provision
3ZB   L   SHA   3-point seat belts, outer rear with ECE label
4E0   L   SDH   Tailgate/trunk lid unlocking from outside
4A3   P   SIH   Seat heater for front seats separately controlled
4GF   L   WSS   Windshield in heat-insulating glass
4K3   L   TKV   Radio remote controlled central locking operated from inside and safe securing
4KC   L   SSH   Side and rear windows in heat-insulatingglass
4L6   P   IRS   Breakaway interior rear view mirror, automatically dimming
4R4   L   FEH   Power windows with comfort operation andcircuit breaker
4SM   L   MSL   Left vanity mirror illuminated with cover and pocket
4TM   L   MSR   Right vanity mirror illuminated with cover and pocket
4U5   L   GNF   Luggage pockets on backrest
4UF   L   AIB   Driver's and front passenger air bag with front passenger air bag deactivation
4X3   L   SAB   Side air bag front with curtain air bag
4Z3   L   HAK   Lockable glove compartment door, with light
4ZB   L   ZIE   Bright moldings
5A4   L   GRV   Trunk lining (design 1)
5B4   P   LER   Backrest release for front seats with "Easy Entry" function (left, electric)
5C0   L   KSA   Without special body measures
5D1   L   TRF   Carrier frequency 433.92 MHz-434.42 Mhz
5K5   L   LAC   Transit coating film with additional transport protection measures
5MD   P   EIH   Decorative aluminum inserts
5RQ   L   ASR   Right exterior mirror: convex
5SL   L   ASL   Left exterior mirror: aspherical
6A0   L   FEU   Without fire extinguisher
6EA   L   ZKS   Without additional side body covers (stone guard)
6FB   L   BBO   Body-colored exterior mirror housings
6KJ   P   KUG   Radiator grille with chrome-plated strip
6P1   L   KZH   License plate bracket rear (ECE)
6PC   L   HBV   Leather hand brake lever handle
6Q2   L   SAG   Leather gearshift knob/handle
6T1   P   INL   Interior light in footwell
6W1   L   KZV   License plate bracket front (large)
6XW   P   ASE   Exterior mirrors: automatically dimming,electrically foldable/adjustable, separately heated
7E0   L   WSA   W/o heat accumulator/auxiliary heating
7A0   L   CDW   Without CD changer/CD player
7AL   P   EDW   Anti-theft alarm system, passenger compartment control, backup horn and towing protection
7K0   L   RDK   Without tire pressure warning light
7M5   L   EIL   Without protective film for scuff plate
7P1   P   LOR   Power adjustable lumbar support in frontseats
7Q0   L   NAV   Without navigation device
7QA   L   CDR   Without CD/DVD for navigation
7R3   L   SLE   Side turn signal lights (white)
7S1   E   WIN   Wind blocker
7X1   E   EPH   Park distance control
8GU   L   GEN   Alternator 140 A
8JW   P   HSW   Twin headlight for driving on the right (gas discharge) w/ integrated high beam
8K3   P   FLS   Separate daytime running lights with low beam assistant and "Coming Home" feature
8N3   P   SWS   Windshield wiper intermittent control with rain sensor
8Q6   P   LWR   Headlight-range adjustment, automatic/ dynamic with fixed and dynamic bending light(AFS 2)
8RM   P   LSE   8 speakers (passive)
8SD   P   SBR   Taillight assembly w/ red colored lens
8T2   P   GRA   Cruise control system (CCS) electronic
8TC   L   NEL   Rear fog light for driving on the right
8W1   P   WWA   Washer fluid level indicator
8WD   L   NES   Integrated front fog light
8X1   E   SWR   Headlight washer system
8Y1   L   SNH   Two-tone horn
8YM   P   RAO   Radio with CD player (high-end)
8Z7   L   MKU   Cold country
8ZH   P   ANT   Antenna for AM/FM reception, "diversity"
9AK   P   HKA   Climatronic with impact pressure control free of cfc
9JB   E   RAU   Smoking package, ashtray front and rear
9M0   L   ZUH   Without auxiliary/parking heater
9P3   L   SGK   Seat belt reminder, electric contact in buckle
9Q5   P   MFA   Multi-function display with control
9T1   P   BWD   Heated washer nozzles, front
9U1   L   BVK   Brake pad wear indicator
9W0   L   VTV   W/o car phone preparation/installation
9WC   L   AUD   Without "Multimedia" in vehicle
1E1   L   AKB   Activated carbon canister
6E3   P   MAS   Front center armrest
A8F   I   AUS   Sports equipment
B0A   L   BLB   Component parts set without country-specific design requirement
B47   L   TPL   Type approval the Baltic States
C5Q   P   RAD   Alloy wheels 7.5J x 17
C06   E   COC   Operating permit, alteration
D2L   I   MOT   4-cyl. gasoline engine 2.0 l/147 kW 16Vturbo FSI, homogeneous Base engine is T59/T61/TQ2/TU2/TD6/TN6
E0A   L   AAU   No special edition
F0A   L   FZS   No special purpose vehicle, standard equipment
FB0   L   LAK   Standard paint coating
FC1   E   IND   Customized installation
G1A   I   GSP   6-speed automatic transmission
G07   L   DFV   Front shock absorption
HK0   P   REI   Tires 235/45 R17 97W x1
J1D   L   BAT   Battery 380 A (72 Ah)
K8K   I   KAR   Convertible
L0L   L   LEA   Left-hand drive vehicle
L19   L   GKV   Suspension range 19 installation control only, no requirement forecast
N3Q   P   SIB   Fine napa leather seat covering
NT1   L   TSP   Transit coating (type 2)
NY0   L   BGK   Standard battery/alternator capacity
P25   G      "Light & Sight" VE
PA1   G      Ambience package with decorative aluminum
PB5   G      Electrically adjustable driver's seat (for leather)
PD1   G      Design package "Chrome and Style"
PH2   G      Air conditioning system "Climatronic"
PJA   G      "Siena" Volkswagen Individual 4 alloy wheels 7 1/2J x 17, titanium silver, tires 235/45 R 17
PT2   G      technical equipment package 2
PU2   G      Multi-function leather steering wheel
PXF   G      Xenon headlights with cornering light - VE -
QG1   L   WIV   Service interval prolongation
QN2   P   SVS   Drawer under right front seat
QR0   L   KMP   Without compass
QV0   L   TVE   W/o TV reception/digital radio reception
REC   G      "RCD 500", 4 x 20 W
T59   I   GMO   4-cylinder gasoline engine 2.0 L unit 06F.C
U5A   L   INS   Instrument insert, km/h speedometer
UF0   L   ESS   Without electric interface
UG0   L   AFH   Without hill hold control / hill descentcontrol / comfort driving assist
V0A   L   REL   Tires w/o specification of tire brand
VC0   L   GRT   W/o remote-controlled garage door opener
VD2   L   WAB   With wind deflector
VF1   P   FHW   Pedal cluster
VK0   L   LFF   Air duct, standard
VL1   L   FGS   Extended pedestrian protection measures
WL4   G      "Napa" leather trim
WW8   G      Winter package VE
X3M   G      National sales program Baltic States
YO2   G      Rolling suitcase set, 2 rolling suitcases, matched to luggage compartment
