VW Bora 1.6 2003
Aloittaja Jonex, 09.05.24 - klo:15:16
Jonex
Terve
Mun Bora heittelee vuorotellen vikakoodia: joko kampakselin asentotunnistin tai nokka-akselin asentotunnistin. Ajattelin vaihtaa molemmat. Mutta kertokaa tälle tumpelolle missä ihmeessä on kampiakselin asentotunnistin. En löytänyt sinne päinkään olevaa edes piuhaa vaikka hortoilin auton alla puoli tuntia. Se nokka-akselin sensori on helpossa paikassa mutta tää kampiakseli??
moottorikoodin kertominen auttaisi, mutta tässä yleisohjeet:
In the 8-valve, the sensor is attached at the front of the block, low down and close to the end of the block, next to the oil filter assembly. There should be nothing else in that area attached to/through the block in that area. The knock sensor is higher up, next to the thermostat housing and by the cylinder head joint.
In the 16-valve the sender wheel is outside the crankcase, just behind the flywheel, and the sensor is mounted on the back side of the block underneath the inlet manifold. Haynes says "access is very difficult", and you have to take the inlet manifold off to get to the sensor.
