Passat -15 ja P1647 vikakoodi
Aloittaja Alffin, 18.09.17 - klo:13:40
Alffin
En ole isommin Volkkareiden kanssa pelannut, mutta nyt harjoittelen Passatin kanssa... Auto on kolarivauriosta korjattu ja airbagejä ja kiristimiä vaihdettu. Vikakoodit sain VCDSllä yhtä lukuunottamatta pois (P1647 Check coding of ECUs on Powertrain Data bus).
Onko niin, että airbagin ecu on vaihdettava kolarin jälkeen, jos tyynyt mossahtaneet?
Tässä AutoScanin koko tarina:
VCDS
Self-Diagnosis Log
Monday,18,September,2017,13:08:20:62198
Page 2
VIN: WVWZZZ3CZHE010775 License Plate:
Address 01: Engine (J623-CZCA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 BR HW: 04E 907 309 AC
Component: R4 1.4l TFS H25 2900
Revision: R7H25---
Coding: 0119003223241D083000
Shop #: WSC 05311 115 00313
ASAM Dataset: EV_ECM14TFS01104E906027BR 001007
ROD: EV_ECM14TFS01104E906027BR.rod
VCID: 75B4E81A054E19CF78C-8020
CAN Converter 01:
1 Fault Found:
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [167] - -
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 32333 km
Date: 2017.09.15
Time: 16:10:02
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 39 °C
Intake air temperature: 20 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 11.826 V
Unlearning counter according OBD: 40
Acceleration: 0.000 m/s²
Cruise Control System (CCS): status-Bit 0: 7
Drivetrain coordinator: ACC fault status-Bit 0: 0
Drivetrain coordinator: ACC fault status-Bit 8: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 0: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 16: 128
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 24: 131
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 8: 0
Drivetrain coordinator: brake fault status-Bit 0: 0
Accelerator pedal travel: 0.00 %
Readiness: 1110 0001
VCDS
Self-Diagnosis Log
Page 3
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 BJ HW: 5Q0 614 517 AG
Component: ESC H62 0636
Revision: 00000000 Serial number: 61536000001014
Coding: 0EEC6A8F34211B6C477E060741C84970562CD8E2608292710020F078C00202
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_Brake1UDSContiMK100IPB 035019
ROD: EV_Brake1UDSContiMK100IPB_035_VW48.rod
VCID: 7AAEFB262C5076B715E-802E
No fault code found.
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 D HW: 3Q0 959 435 D
Component: VWKESSYMQB 026 0811
Revision: 00026000 Serial number: 0405622852
Coding: 002F0F0E0F
ASAM Dataset: EV_KessyHellaMQBAB 004039
ROD: EV_KessyHellaMQBAB_004_VW37.rod
VCID: 3B203E2263EA8FBF4E8-806E
Sensor Controlled Power Rear Lid:
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 AK HW: 5G0 907 426 AK
Component: AC Manuell H03 1601
Revision: 00001K06
Coding: 11020004200110001000400000000002
ASAM Dataset: EV_ACManueBHBVW37X 004132
ROD: EV_ACManueBHBVW37X_004_VW37.rod
VCID: 74B2D51E0E3400C74F2-8020
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
VCDS
Self-Diagnosis Log
Page 4
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 086 BG HW: 5Q0 937 086 BG
Component: BCM PQ37BOSCH 032 0222
Revision: -------- Serial number: 865826051601DN
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
ROD: EV_BCMBOSCH_017_VW27.rod
VCID: 005A89CE4A8C2C675BA-8054
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160505 042 0607
Serial number: 160520153149
Coding: 0E4DDD
Light switch:
Subsystem 2 - Part No SW: 3G0 941 633 C HW: 3G0 941 633 C
Component: E1 - LDS MQB H01 0032
Serial number: 08 03 2016 10001411
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39331614200225
Coding: 0051051001
Shop #: WSC 05311 115 00084
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_002_VW37.rod
VCID: 44D245DE1E14F0473F2-8010
VCDS
Self-Diagnosis Log
Page 5
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 BB HW: 3Q0 959 655 BB
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003STPARCFP2
Coding: 88CCC000000000005C5400CC000800000065
Shop #: WSC 05314 000 00001
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F580A323772539F220-802A
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 454 000 305 16
Component: SideSensor_Df 008 0887
Serial number: 3576U000000C44ECBA1X
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 454 003 004 16
Component: SideSensor_Pf 008 0887
Serial number: 3586U000000AC52D3A1M
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 454 800 905 16
Component: SideSensor_Dr 301 0148
Serial number: 3516R6F55850A000000A
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 454 802 204 16
Component: SideSensor_Pr 301 0148
Serial number: 3526R0573850A000000
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 454 801 401 14
Component: FrontSensor_D 114 0149
Serial number: 3556V02B4A502000000+
Coding: 2D2D2D
VCDS
Self-Diagnosis Log
Page 6
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 3Q0 953 521 CS HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160511500499
Coding: 0000
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB_VW37.rod
VCID: 035086C25B9A377F468-8056
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 3G0 920 740 B HW: 3G0 920 740 B
Component: KOMBI 202 9630
Coding: 07A402102380000801082B001000000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009007
ROD: EV_DashBoardJCIMQBAB_009.rod
VCID: 221EE346E440DE776DE-8076
VCDS
Self-Diagnosis Log
Page 7
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AL HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2265
Revision: -------- Serial number: 22051610801830
Coding: 030300047F085700FB000048080F00010001070000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013_VW37.rod
VCID: 7BA0FE22236A4FBF0E8-802E
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 29150002159150045442
Coding: 2CFFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75410803001605190185
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000114584008
Coding: 0000000000000000
ASAM Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 71BCDC0A712635EFA44-8024
VCDS
Self-Diagnosis Log
Page 8
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 150516EEE1761A
Coding: 00300B208000020000001000
ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
VCID: 41DC4CCA0106E56F144-8014
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q4 959 812 E HW: 5Q4 959 812 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000003746251
Coding: 010000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000817345
Coding: 01000010005000
Shop #: WSC 00015 115 00313
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_008_VW37.rod
VCID: 3D24303A7DFE818F70C-8068
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 010516EE11255A
Coding: 003001208000020000001000
ASAM Dataset: EV_DCUPasseSideEWMINKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
VCID: 40DA49CE0A0CEC671BA-8014
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 E HW: 5Q4 959 811 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000003741753
Coding: 090000
VCDS
Self-Diagnosis Log
Page 9
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 5G0 035 869 B HW: 5G0 035 869 B
Component: MU-E--ER 050 7064
Serial number: 09051600011202
Coding: 02840100FF00000041110001000002001F0000840000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW12.rod
VCID: 2D04007AAD9E110FC0C-8078
End----------(Elapsed Time: 01:30, VBatt start/end: 12.2V/12.2V)-----------
