Jetta 2.0 TFSI -07
Aloittaja jaris, 18.09.10 - klo:23:03
jaris
Rek 27.12.-06.
Manuaali vaihteet.Entisessä elämässä työsuhdeautona,ei mitään lisävarusteita(tietääkseni?) normi sportline,joka on ollut ainoa varustetaso tämän moottorin kanssa.Talvipyörissä sportlinen http://4130-products.com/wheels/Bionline5_AJ.html alut ja kesäpyörissä kuvissa olevat Fondmetal FN7200 molemmat setit 16".
Jälkiasenteinen orig.vakionopeudensäädin,sumuvalot poistettu edellisen omistejan toimesta.
Erona muihin malleihin,maalatut puskurien alaosat, pakoputken tupla ulostulo ja punainen I kirjain mallimerkinnässä.
Varusteet:
väri = LD5Q Shadow Blue
X1B = National sales program Finland
CM5 = Alloy wheels 6.5J x 16
G0K = 6-speed manual transmission
H6U = Tires 205/55 R16 91W
J1L = Battery 280 A (60 Ah)
K8B = Notchback
4UF = Drivers and front passenger air bag with front passenger air bag deactivation
D2L = 4-cyl. gasoline engine 2.0 l/147 kW 16Vturbo FSI, homogeneous Base engine is T59/T61/TQ2/TU2/TD6/TN6
U5A = Instrument insert, km/h speedometer
1LJ = Disc brakes, front
V0A = Tires w/o specification of tire brand
0A2 = 4 doors
1AT = Electronic stabilization program (ESP)
1G2 = Steel spare wheel with original equipment tires
1MW = Leather steering wheel
2JC = Comfort bumpers
5RQ = Right exterior mirror: convex
7K0 = Without tire pressure warning light
2UC = Sports version
5SL = Left exterior mirror: aspherical
0HM = Vehicle class differentiation -1KM- Build status corresponds to production in Mexico
4X3 = Side air bag front with curtain air bag
0GG = Emission standard EU4
3L3 = Manual height adjustment for front seats
3T2 = Three rear headrests
QC1 = Dark tinted glass in rear seat area heat-insulating glass in front area
3YR = Door pockets with insert mats
4A3 = Seat heater for front seats separately controlled
8BC = Headlight with gas discharge lamp and turn signal light for driving on the right
L58 = Suspension range 58 installation control only, no requirement forecast
G57 = Front shock absorption
8YL = Radio with CD player
B0A = Component parts set without country-specific design requirement
1N3 = Speed-related variable steering assist (Servotronic)
3FA = Without roof insert (standard roof)
4K3 = Radio remote controlled central locking operated from inside and safe securing
4R4 = Power windows with comfort operation andcircuit breaker
8Y1 = Two-tone horn
8ZH = Antenna for AM/FM reception, "diversity"
9AP = Climatic air-conditioning system (semi-automatic)
CX-5 awd
JoJio
Komia jetta, mutta miks ihmeessä on pitäny poistaa sumuvalot? ??? ensinnäkin keula on joka autossa paljon hianompi kun ne on, eikä ole... Mut tapasan kullakin.. Eikös tää oo pelkkä TSI?
Kiviharju
Hyvännäköinen "sleepperi", eipä moni arvaisi että tässä on 200hv :D
Lainaus käyttäjältä: JoJio - 18.09.10 - klo:23:48
Tuohon aikaan olivat vielä TFSI merkinnällä. Tämä nykypäivän TSI on aika uusi juttu.
Audi A4 Allroad quattro -17
jaris
Varmaan kustannus syistä kun on puskuri uusittu  ::)
Voishan noi laittaa takaisin jos löytäis sopivasti,niin sais virheilmoituksen toimimattomista sumuvaloista pois samalla ;)
CX-5 awd
Reneto
#4
Tämä on susi lampaan vaatteissa..  ;D
Tumma sininen sopii mielestäni hyvin Jettaan. Onko muka tosiaan niin, ettei vakkari ole ollut vakiovaruste sportlinessä? Omassa comfortlinessäkin se on vakiona..
edit: vilkaisin autowikistä, ja niin se taitaa olla että vakkari ei ole vakiona sportlinessä
Lainaus käyttäjältä: jaris - 19.09.10 - klo:09:14
Vcds:llä ruksi kohdasta "Front fog lights installed" pois ja häiriövalon pitäis kaikota.
Sitten GLI maskia vain...
http://oemplus.com/index.php?main_page=product_info&cPath=75_23_30&products_id=149
Mutta jostain halvemmasta paikasta  ::)
Häilis
Sumuvalot + tarvikket täältä -> http://www.hz-design.eu/shop/index.php?cat=c19_VW-Jetta-1K2.html&XTCsid=c598be3bde41145e3d04731f9364030f
jos sulla on johdot/valokytkin sumuvalotoiminnolla kerran valmiina niin sumuvalot+sumuvalokehikot noin 125e postikuluineen.
James
#7
Ainut vaan että nuo Gli/Gti:n sumuvalo ritilät eivät käy suoraan Jettaan.
Osat saa kyllä istumaan paikalleen nätisti ,mutta tarvitsee leikellä ja liimata. Johtuu noista kromilistoista tuon sumuvaloritilän yläpuolella.
Kiinnitysruuvit on väärällä korkeudella. Nuo kromilistat täytyisi liimata kiinteästi etupuskuriin. Ja noista gli/gti ritilöistä täytyy leikata noin pari senttiä yläosasta pois. Edelliselle autolle tein noin ja silloin tilasin kaikki hilppeet Kcs:ltä hinta oli jotain alle 200â,¬.
Maski ja keskiritilä käy suoraan paikalleen.
Tikka
On kyllä hienon värinen Jetta. En ole edes varma, että olisin tuolla värillä Jettaa nähnytkään.
jaris
Oho...ompas täällä nyt kehuttu  :o
Ajattelin saavani vain moitteita näin huonoista kuvista,ala-arvoisista ja pienistä vanteista sekä maasto-automaisesta olemuksesta ;)
Lisätty aloitukseen lista varusteista.
Lainaus käyttäjältä: Tos® - 19.09.10 - klo:10:14
Tuota kesällä ohjelmoitiin,mutta jotain meni pieleen,kun laitoin sumuvalot päälle niin vika ilmoitus palasi,ehkä kuitattiin vain vika pois? En muista kokeiltiinko silloin takasumuvaloa...tuskin tuli mieleen kesähelteillä.
CX-5 awd
Lainaus käyttäjältä: jaris - 19.09.10 - klo:18:06
Saattaahan tuo herjata, kun valokytkimestä löytyy etusumarit...
aaa
jaris
#12
Pientä paivitystä, viimekesänä asennettu kiinalaiset sumuvalot(heh,täyttä sontaa teippiä päälle katsastukseen) ja Liettuasta tulleet valoritilät sekä uudet jarrupalat eteen ja taakse, kuukausi sitten uusittu ennakoiden bensapumpun nokka-akselin seuraaja(http://changegears.wordpress.com/tag/06d109309c/)
Viime lauantaina, elämäni eka kiihdytys kokeilu VW-openissa Kiikalassa, 1/4mile 15,217s ja 153,65km/h.
Heinäkuussa tulee kaksi vuotta täyteen ilman murheita(tuolloin hajos ilm.kompura joka vaihdettiin maahantuojan kustannuksella).....tällä hetkellä mittarissa 135 tkm.
CX-5 awd
d-spec
Golf 5 BKD 4motion, Passat 3C 4M CR R-Line 4motion,
Toyota Ma70 7M-GTE, MB W201 1,8E.
JMP
Miltä sun nokka-akselin seuraaja näytti kun vaihdoit sen? Aika vähän noita ilmeisesti menee ison veden tällä puolen.. Mietin kans pitäiskö kurkata oman TFSI tilanne kun alkaa 100t kohta tulla mittariin.
jaris
Lainaus käyttäjältä: JMP - 29.06.12 - klo:11:02
Kiiltäväks muuttunu, eipä kummempaa, en tosin tiedä miten paljon tuo pinnoitteen häviäminen vaikuttaa kestoikään, muttei itse metalli kuitenkaan miksikään ollut tullut. Tuo maksoi jotain~35â,¬ ettei siinä isoja menetyksiä tule vaikka sen vaihtaa. Voin iltasella laittaa kuvatuksen.
CX-5 awd
Vaggis
#16
jaris
Lainaus käyttäjältä: Vaggis - 09.02.13 - klo:09:21
Tämä Jetta vaihtoi omistajaa, mutta ei se mitään, jatketaan tästä. Kesäksi tuli hommattua TSW : n lagunat koossa 8x19''. Nyt pitäs ruveta pikkuhiljaa alustaa katteleen.
Moro,  mun puolesta voit jatkaa tähän samaan jos tykkäät, älä ny tee kivirekee kuitenkaan;).....
CX-5 awd
Vaggis
#18
sambolo
Ã,,äni ehdottomasti lagunoille! Nuo haamut näyttää jotenki vähän halpamaisilta : I
Octavia RS III
Ex vag:
5F Leon 1.4 tsi style
08 Leon TDI FR
07 Ibiza FR
johansa
Samoin, Lagunat on tyylikkäämmät minunkin mielestä.
Auto: Porsche Macan 2017
Vaggis
#21
