Golf V ABS probleema + vikakoodit
Aloittaja 400 cid, 31.08.19 - klo:19:42
400 cid
Hei,
seuraavanlainen ongelma: ABS, ESP valot palaa ja käsijarrun merkkivalo vilkkuu.
Delphin laitteella saatiin vikakoodi 01130 -abs järjestelmää häiritty, ulkoinen häiriö.
Nyt katsottiin VagComilla (kiitos HeiTik) ja tuli tällaiset vikakoodit:
Saturday,31,August,2019,10:53:58:52562
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WVWZZZ1KZ9M261464   License Plate:
Mileage: 369290km-229466mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 69 72 76
VIN: WVWZZZ1KZ9M261464   Mileage: 369290km-229466miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 PM    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000SG  1136
   Revision: --H08---    Serial number: VWX7Z0H624806L
   Coding: 0000071
   Shop #: WSC 66565 257 00032
   VCID: 79F863B530140087DE-802C
3 Faults Found:
006480 - Radiator Fan (V7)
               P1950 - 000 - Movement Restricted / Jammed - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 3
                    Fault Frequency: 205
                    Reset counter: 255
                    Mileage: 359068 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:46:22
             Freeze Frame:
                    RPM: 1890 /min
                    Speed: 89.0 km/h
                    Load: 0.0 %
                    Voltage: 14.36 V
                    Bin. Bits: 01101000
                    Temperature: 82.8°C
                    Duty Cycle: 9.7 %
006470 - Control Module 1 for Coolant Fan
               P1946 - 000 - Defective - Intermittent
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 60
                    Reset counter: 255
                    Mileage: 361459 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:50:30
             Freeze Frame:
                    RPM: 1512 /min
                    Speed: 38.0 km/h
                    Load: 16.1 %
                    Voltage: 14.21 V
                    Bin. Bits: 00101000
                    Temperature: 83.7°C
                    Duty Cycle: 9.7 %
001681 - Fan 1 Control Circuit
               P0691 - 000 - Short to GND - Intermittent
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 364152 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:43:37
             Freeze Frame:
                    RPM: 2856 /min
                    Speed: 134.0 km/h
                    Load: 62.4 %
                    Voltage: 14.44 V
                    Bin. Bits: 00101000
                    Temperature: 88.2°C
                    Duty Cycle: 9.7 %
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0120
   Revision: 00H35001
   Coding: 113B200D092800FB880F04EA901D00413400
   Shop #: WSC 60731 001 1048576
   VCID: 76E26889C10A6FFFB3-8022
2 Faults Found:
01130 - ABS Operation
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 254
                    Mileage: 367611 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 0
                    Count: 0
                    Count: 4608
                    Count: 125
                    Count: 49422
                    Count: 65019
                    Count: 0
                    Count: 0
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 59
                    Mileage: 367632 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 7
                    Count: 32768
                    Count: 4608
                    Count: 397
                    Count: 52061
                    Count: 0
                    Count: 0
                    Count: 0
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 DA    HW: 1K0 907 044 DA
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 69D833F540B4B0072E-803C
No fault code found.
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000000997790
   Coding: 0A8B8F2700041500470000001C00000000087B075C000120000000000000
   Shop #: WSC 00066 000 00000
   VCID: 71E85B95686448C766-8024
   Subsystem 1 - Part No: 1K1 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 170708 021  0501
   Coding: 00038805
   Shop #: WSC 00066
2 Faults Found:
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 48
                    Mileage: 349680 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 12.55 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
00526 - Brake Light Switch (F)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 84
                    Mileage: 369165 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 13.55 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: 5P AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD22LPCP
   Coding: 0013648
   VCID: 3D70B7A564BCFCA7B2-8068
   Subsystem 1 - Serial number: 6332MSME29026C2EI
   Subsystem 2 - Serial number: 6342MSME2573297EL
   Subsystem 3 - Serial number: 6351HSME16624B704
   Subsystem 4 - Serial number: 6361HSME16615959A
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 CB    HW: 1K0 953 549 CB
   Component: J0527           051 0101
   Coding: 0002022
   VCID: 74E6528117767DEF8D-8020
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
5 Faults Found:
00576 - Terminal 15
            012 - Electrical Fault in Circuit - Intermittent
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K0 920 874 B    HW: 1K0 920 874 B
   Component: KOMBIINSTRUMENT 3HL 2416
   Revision: V0002000    Serial number: VWX7Z0H624806L
   Coding: 0007103
   Shop #: WSC 80093 222 69422
   VCID: 2C568AE18FC6652F15-8078
Address 19: CAN Gateway        Labels:. 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 Q    HW: 1K0 907 951
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 030608F1000903
   Coding: E9817F4E0002022002
   Shop #: WSC 24500 205 21834
   VCID: 3560AF855C8C24E77A-8060
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            3HL 2416
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
   Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1519
   Revision: 71009005    Serial number: 00000512388702
   Coding: 0000180
3 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
             Freeze Frame:
                    Fault Status: 01111000
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 48
                    Mileage: 319229 km
                    Time Indication: 0
00913 - Window Regulator Switch; Front Right Driver (E81)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 7
                    Reset counter: 87
                    Mileage: 365980 km
                    Time Indication: 0
00109 - Left Mirror Turn Signal Lamp (L131)
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 5
                    Reset counter: 48
                    Mileage: 342763 km
                    Time Indication: 0
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 69     2301
   Revision: 00H15000
   VCID: 2A5A8CF985327B1FE7-807E
1 Fault Found:
01316 - ABS Control Module
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 49
                    Mileage: 367623 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:55:25
             Freeze Frame:
                    Voltage: 12.13 V
                        DU
                    Temperature: 14.0°C
                    RPM: 0 /min
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
                    Count: 0
Address 46: Central Conv.        Labels:. 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 8090020052830C7F2D0484056008CF03E0FC00
   VCID: 0304015D42D84A5784-8056
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
1 Fault Found:
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 4
                    Reset counter: 31
                    Mileage: 319245 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:02:58
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
   Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1519
   Revision: 71009005    Serial number: 00000041288518
   Coding: 0000436
   VCID: 72EA54996D6273DF9F-8026
Address 55: Headlight Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000003
2 Faults Found:
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
            010 - Open or Short to Plus
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  012 0029
   Revision: 00000000    Serial number: VWZ1Z2H5333641
   Coding: 0500040004
   VCID: 65C03FC56CAC94670A-8030
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R
   Component: J388   TUER-SG HL   1401
   Revision: 11006001    Serial number: 00000003313788
   Coding: 0000144
   VCID: 75E06F851C0C64E7BA-8020
Address 69: Trailer        Labels: RETROFIT69.lbl
   Part No SW: 5F0 01V 000 6    HW: 8P0 907 383
   Coding: 0000001
   Shop #: WSC 00000 211 66245
   VCID: 285E76F19B3E490FF1-807C
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R
   Component: J389   TUER-SG HR   1401
   Revision: 11006001    Serial number: 00000003291131
   Coding: 0000144
   VCID: 76E26889010A6FFFB3-8022
2 Faults Found:
00099 - Rear Right Central Locking (Safe) Motor (V164)
             Freeze Frame:
                    Fault Status: 01111100
                    Fault Priority: 3
                    Fault Frequency: 232
                    Reset counter: 48
                    Mileage: 0 km
                    Time Indication: 0
00931 - Locking Module for Central Locking; Rear Right (F223)
             Freeze Frame:
                    Fault Status: 00111000
                    Fault Priority: 3
                    Reset counter: 86
                    Mileage: 342343 km
                    Time Indication: 0
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 38 Einparkhilfe     0101
   VCID: 2D5087E5B4DC6C2702-8078
2 Faults Found:
00437 - Rear Right Inner Parking Aid Sensor (G335)
            006 - Short to Plus
00436 - Rear Left Inner Parking Aid Sensor (G334)
            006 - Short to Plus
End-------------------------(Elapsed Time: 01:59)--------------------------
...voiko näistä päätellä jotain vikaa ABS:n osalta, ABS-moduuleitahan näistä on ilmeisesti mennyt...
-ja autohan oli 2008 VW Golf Variant 1,9 TDI
dwntime
Tsekatkaa VCDSllä ABS measurement valueistase brake pressure arvo. Jos se näyttää utopistisia lukemia tai lukemat muuttuvat erikoisesti kun jarrua painelee, on ABS yksikkö kaput.
Romikselta uusi tilalle ja kovaa ajoa. Katot vain että on samalla osanumerolla niin säästät hermoja koodailujen kanssa :)
400 cid
Hitsi kun on taas kaukana toi VCDS...
Eipäs älytty katsoa samalla noita arvoja, muuta kuin vikakoodit.
Meinaatko yksiköllä tota älyboksia vai mekaanista yksikköä vai koko settiä..
noita sähköbokseja vissiin saa korjattuakin...
Ei vaan viitsis alkaa purkamaan ja lähettelemään korjattavaksi jos vika onkin jossain muualla..
ETKA kertoo, että auto on valmistettu 26.7.2008 ja on vuosimallia 2009.
Pelkän ohjainlaitteen varaosanumero on 1K0907375AN ja koko paketin 1K0614517BD tai 1K0614517BJ, hintaa melkein 1800â,¬ ::)
Saattaa olla hankala löytää oikeaa osaa käytettynä kun tuossa tulostuksessa on vielä pari muutakin varaosanumeroa...
dwntime
Ei ole vaikea löytää. Hakee pelkällä ohjainlaitteen osanumerolla. Sillä saa riittävän tarkan.
On tullut näitä ihan käytännössäkin muutamia vaihdettua....
dosetti
Onko dwntime tuollainen abs-yksikkö kovinkin vaikea vaihtaa? Itselläni on Jetassa se brake pressure-vikakoodi ja ilmeisesti se sensori on siellä abs-yksikön sisällä eli menee vaihtoon se yksikkö, briteistä 230eur, mutta vaihtotyö on vielä tällä hetkellä auki, miten se kannattaa suorittaa (suorituttaa).
400 cid
Tossa pumpun kupeessa on 1KO 614 517 BD.
Saako sen pelkän boksin irti irroittamatta koko mööpeliä jarruputkineen, aika ahtaan tuntuisesti on ne ruuvit siellä takapuolella..
Vekatronics noita bokseja ilmeisesti korjaa parilla sadalla, mutta miten varmistun siitä, että se vika nimenomaan on siinä älyboksissa?
Vai viittako tämä oire automaattisesti siihen?
dosetti
Kiitos Vekatronics-vinkistä. Posteineen menee siis melkein samaan kuin briteistä tilaamalla. Briteistä saa vielä takaisin jotain jos lähettää viallisen sinne, mutta postimaksut on aika paljon. Elinikäinen takuu briteissä korjatulla, Vekatronicsilla 1-2v. Mielelläni itsekin ottaisin vaihto-ohjeita itse työn suorittamiseen..
400 cid
Onkos sulla, dosetti samalla numerolla toi?
Mulla olis ylimääräisenä purkuautosta 1 KO 614 517 AF - 1 KO 907 379 AC - setti.
Tietenkään ei käy omaan autoon...  :-\
dosetti
Lainaus käyttäjältä: 400 cid - 03.09.19 - klo:08:11
Täytyypä käydä katsomassa. Käytettykin voisi kiinnostaa, vaikka niistähän ei tiedä kauanko kestää. Ilmoittelen vaikka yv:llä lisää. Sillä välin jos joku haluaa kertoa homman tehneenä, onko itse tehtävissä parkkipaikalla ja tarvitseeko vcds. Pikkuhommat itse menee, mutta tuosta ei mitään hajua. Jossain sanottiin, että olisi hyvä laittaa palkki painamaan jarrupoljinta putkien irroituksen ajaksi, eikä ne nesteet nimenomaan silloin tule paremmin pois sieltä?
En ole vaihtotyötä tehnyt, mutta jälkihoitoa kyllä. VCDS tarvitaan jotta vaihdon jälkeen saa suoritettua kaikki tarpeelliset koodaukset ja testit. Ja aina, aina etukäteen auto-scan jotta boksin koodaus on tallessa. MK60EC1 koodaus on yksilöllinen jokaiseen autoon eikä sitä jokapoika saa laskettua. Helpompi ottaa alkuperäisestä ylös ennen irrotusta.
Jos jarrupoljin on remontin ajan painettuna alas, niin säiliö ei tule tyhjäksi. Jos poljinta ei paina, niin koko säiliöllinen valuu maahan.
Skoda Enyaq iV 80x 4x4 -23
dwntime
M_M tuossa kiteyttikin hyvin prosessin.
Tärkein on se että jarrupoljin on painettuna, muuten sieltä tulee nesteet ulos.
Vaihto itsessään on helppo. Jarruputket irti ja yksikkö lähtee nostamalla pois. Sitä ei ole pultattu alustaan kiinni vaan menee sellaisten kumituttien sisään.
Uusi paikoilleen, putket kiinni ja ilmaus. Ilmaus helpoin hoitaa VCDSllä kun sillä saa pumpun myös täytettyä, mutta onnistuu kyllä perinteiselläkin menetelmällä.
Diesel moottorisessa autossa tuo pumppu on vähän ahtaassa paikassa ja olikohan isommassa dieselissä ainakin DPF pönttö edessä.
dosetti
#12
Minulla lukee mustan osan kyljessä 1 KO 614 517 AA. Onko tuo kumman osan numero ja ilmeisesti ei sitten käy? Musta osa taitaa olla se elektroniikkaosa eli jos vaihtaa pelkän metalliblokin eli sen metallin värisen osan, jossa viallinen anturi on, ei tarvitse koodausta suorittaa. Onko noiden osien irroituksessa toisistaan tai yhteenliittämisessä mitään erityistä huomioitavaa? Näyttäisi siltä, että itse tuon saisi otettua irti. Briteissä myydään pelkkää metallinväristä osaa 250eur ja 40eur saa takaisin, elinikäinen takuu osalla.
400 cid
Lainaus käyttäjältä: M_M - 04.09.19 - klo:15:03
Onkos toi boksin koodaus tuo, mikä näkyy tässä mun ylempänä olevassa skannauksessa? Vai pitääkö olla vielä joku muu?
"Address 03: ABS Brakes (-----)       Labels:. 1K0-907-379-60EC1F.clb
   Revision: 00H35001
   VCID: 76E26889C10A6FFFB3-8022  "
Coding: 113B200D092800FB880F04EA901D00413400 on se koodaus
400 cid
Nyt vielä käytin paikallisessa korjaamossa ja Boschin testerissä ja kyllä se vika boksiin viittaa.
Soitin sitten Elehuoltoon ja siellä oli tuomio se, boksi vika on sellainen joka ei ole korjattavissa. Ja huomattavan yleinen...  :(
Eli nyt vaan vaihtoehtoina uusi (Elehuollon mukaan toista tuhatta marmosritiskillä) tai sitten käytetty ehjä.. sellaisen kun vaan kohtuuhintaan löytäisi jostain...  ::)
Mielenkiintoinen diagnoosi ettei mukamas ole korjattavissa.
Audifinnsin foorumilta löytyy nimimerkki amalin joka korjailee noita bokseja, voisit häneltä kysäistä vielä mielipidettä.
400 cid
Lainaus käyttäjältä: Jultsu - 20.09.19 - klo:23:39
Kyllä se kaveri siellä sen järkeenkäyvästi selitti, miksei ole korjattavissa. Noissa on kuulemma ihan tyyppivikana prosessorivika, ja se taas on sillä keinoin kasattu alumiinilämpölevyineen, että korjaaminen on käytännössä mahdotonta muualla kuin jossain elektroniikkatehtaassa.
Eli sen boksin jonkun systeemin avaus vaatii lämpöä joka taas tekee vahinkoa jossain toisessa kohdassa.
dosetti
Ilmeisesti laitteesta riippuen tarvitsee tai ei tarvitse koodauksia kun nyt on kahta varmaa tietoa siitä, kyllä ja ei. Toinen asia, josta ei ole varmuutta, saako nuo mustan ja hopean värisen osan toisistaan helposti kotikonsteilla irti eli riittää kun vaihtaa vain tuon hopean värisen osan. Näihin kun löydän vastauksen niin uskaltaa lähteä tilaamaan koko osaa mistään..
Laitoin YV:llä yhden kaverin nimen, jolla on tuollainen auto purettuna.
400 cid
Benecarsilta löytyi tuollainen käytetty kohtuuhinnalla.. saa nähdä kun se mötikkä sieltä saapuu että miten sen kanssa käy...
400 cid
No niin, eli paketti tuli, samalla numerolla ja asensin paikoilleen.
Valot vilkkuivat samalla lailla, paitsi pimputus ei loppunut ollenkaan.
Menin korjaamolle, jossa on vcds käytössä ja asennettiin koodaus vanhan mallin mukaan.
Sitten alkoi tulla vikakoodeja ohjauksesta, jarrupaineesta ym. eli laite vaati vielä sopeutuksia.
Siinä vaiheessa loppui asentajalta tietämys ja sanoi että voin halutessani itse koittaa jatkaa.
No rosstechin sivulta etsiskelin apuja ja tunnin verran siinä säätelin ja lopulta homma onnistui!!
Eli nyt toimii. :)
Hyvä homma. Paljonkos osa muuten maksoi?
Kaverilla, jonka yhteystiedot tuossa annoin YV:llä sanoi, että hänellä on noita parisenkymmentä varastossa ja hinta ei päätä huimaa ;D
400 cid
150e maksoi koko abs-yksikkö Benecarsilla.
Ei mulle ainakaan ole tullut mitään yksityisviestiä...  :-\
Kolmanneksen olist ehkä säästänyt hinnasta. Joskus YV:t toimii ja joskus ei ??? Tai sitten jäi "Lähetä" nappula painamatta...
400 cid
Lainaus käyttäjältä: o.b. - 03.10.19 - klo:22:45
Joo...
no pääasia että vehje on nyt kunnossa ja tänään leimattu huomautuksitta.   :D
TDiih
#26
Vaihdoin kaverin ocuun korjatun yksikön, vaihto meni ihan ok ja kiitos erityisesti M_M:lle. :)
Vaihdoin samaiseen kulkineeseen myöhemmin takasylinteriin uuden männän ja tiivisteet, ja nyt on ongelmana pehmeä poljintuntuma. Useammasta ilmauksesta huolimatta poljin ottaa vasta puolessa välissä kiinni. Jarrupaineet ovat VCDS:n mukaan 160 baria, eli mielestäni todella hyvät. Onkohan pääsylinterin tiivisteet menneet rikki vai voiko ilmaa olla vielä jossain? ABS-yksikkö on ilmattu nyt kolmeen kertaan ja joka kerta tuntuma on hieman parantunut. Takasatulat ilmattu ainakin viiteen kertaan.
Jotain täytyy ennen talvea tehdä, kun hätäjarrutehostin paukuttelee hyvin herkästi  ;D
Octavia BKD DSG
VW Golf 1.9 TDI -98
Martti87
Moro!
Taitaa olla vanha asia, mutta elehuolto korjaa näitä nykyään. Korjautin omasta autostani kyseisellä ongelmalla ohjainlaitteen Tampereen elehuollossa ja hienosti on toiminut. Takuukin tuli laitteelle. Tuossa linkki heidän nettisivuille kyseiseen tuotteeseen:
http://elehuolto.fi/23-absjarrut-kat/506-abs-jarrut-vw-ate601-bga
Onpa tyyris. Bratwurstimaassa korjaavat noita alle puoleen hintaan tuosta ja takuukin on tuplat. No kotimaista yrittämistä pitää tukea ;)
tsiih
Lainaus käyttäjältä: o.b. - 08.12.22 - klo:20:23
Voitko vinkata mistä löydän bratwurstimaan korjaajan. Brittejä kyllä löytyy googlesta.
