Yeti (5L) koodausta
Aloittaja Late, 09.01.12 - klo:09:44
Late
Oven-ohjainlaitteen koodaus:
Etu ovet:
Byte 0 = ei koodattavissa
Byte 1
Vakioarvo = 00010000
Surround valaistus = xxxxxxx1
Exit valo = xxxxx1xx
Oven kahvan valo = xxxx1xxx
J519 koodaus "softaversio 575"
  Byte 0     Byte 1    Byte 2            Byte 30  Bytes
  0h   1h    2h   3h   4h   5h   ....... 60h  61h  Hex numbers
XXXXXXXXXXXXXXXXXXXXXXXX.......XXXXXXXX
765432107654321076543210       76543210 Bit assignment
Selitykset lyhenteille:
AFL - automatic driving light switch-on function
CORNER - fog lights with corner PR. Number 8WD
ATA - anti-theft alarm
2EFH - Electrical front window regulators
4EFH - Electrical front and rear window regulators
EFP - EFP relay
FFB - radio remote control
AC - Climatronic, Climatic, air conditioning system with electronic control PR. Number 9AK, 9AP, KH6
L0R - Right hand steering
MAXI DOT - dash panel insert with MAXI DOT display
MS - seat memory, driver seat
EB L - emergency brake light function
NBL - fog light
RS - Rain sensor PR. number 8N3, 8N6
STG - sliding/tilting glass roof, electric with sunscreen/sunblind PR. number 3FU
          (Panorama sunroof)
SIH - seat heating
HWS - headlight washer system
AH - auxiliary heater PR. number 9M9
TANK E - fuel tank lid, electrical PR. number 2W3
TANK M - fuel tank lid, mechanical
CL - central locking
CL SAFE 1 - Door lock with Safe Motor - Standard
CL SAFE 0 - Door lock without Safe Motor - only Netherlands PR. number 4I1, 4I2
XENON - Xenon headlights
MAXI DOT 1 - vehicle with MAXI DOT display
MAXI DOT 0 - vehicle without MAXI DOT display
Byte 0
Default value = 01000000
CL SAFE 0 = xx1xxxxx
L0R 1 = xxxx1xxx
Byte 1 Not possible always = 00011000
Byte 2 not possible always = 00001010
Byte 3
Default value = 10111000
STG 1 = xxxxxx11
Byte 4
Default value = 10110000
MAXI DOT 1 + RS 1 = x1xxxxxx
MS 1 = xxxx1xxx
Byte 5
According to the SW version:
ATA 0 = 00000101
up to 0537
ATA 1 = 01000001
from 0538
ATA 1 = 01011011
Byte 6
CL 1 = 00001100
CL 1 + FFB 1 = 00001000
CL 1 + FFB 1+ ATA 1 = 11110001
Byte 7
Default value = 10100000
TANK E 1 = xx0xxxxx
4EFH 1 = x1xxxxxx
2EFH + CL SAFE 1 = xxx10xxx
2EFH + CL SAFE 0 = xxx01xxx
Byte 8 not possible  always = 01000000
Byte 9 not possible always = 00010000
Byte 10 not possible always = 00000000
Byte 11 not possible always = 10000000
Byte 12 not possible always = 00000001
Byte 13 not possible always = 00000000
Byte 14
Default value = 00000000
NBL 1 = xxxxxxx1
XENON 1 = xxxx1xxx
CORNER 1 = 1xxxxxxx
Byte 15 not possible always = 11100100
Byte 16
Default value = 00000001
EB L 1 = xxxxxx1x
Byte 17
CORNER 1 = xxxxxxx1
XENON 1 = xxxxx1xx
AFL 1 = x111xxxx
Byte 18 not possible always = 00000000
Byte 19 not possible always = 10101110
Byte 20
Default value = 01010010
HWS 1 = xxxxxx11
Byte 21
Default value = 01001101
RS 1 = xx1xxxxx
Byte 22
SIH 1 = xxxxx1xx
EFP 1 = xxxx1xxx
AH 1 = xx1xxxxx
AC 1 = 1xxxxxxx
Byte 23 not possible always = 01100000
Byte 24 not possible always = 01011100
Byte 25
XENON 1 = xxxxx1xx
MAXI DOT 1 = xxxxxxx1
Byte 26 not possible always = 01000000
Byte 27 to Byte 29
Not possible always = 00000000
Late
J519 koodaus "softaversio 615"
EFP - EFP relay
WH - windscreen heater
Luggage Compartment Light Switch -F5-
KL58D - instrument and number plate lighting switch-off in the event of continuous parking light
CW - calendar week
NBL - fog light
          (Panorama sunroof)
SIH - seat heating
START - start/stop system with recuperation PR. Number 7L6
Byte 0
L0R 1 = xxxx1xxx
Byte 1
Until CW 45/2010 = 00011000
From CW 45/2010 = 00000000
F5 0
Byte 3
STG 1 = xxxxxx11
Byte 4
MS 1 = xxxx1xxx
Byte 5
Default value = 00000101
ATA 1 = x1x1101x
Byte 6
CL 1 = 00001100
Byte 7
TANK E 1 = xx0xxxxx
4EFH 1 = x1xxxxxx
Byte 9
Default value = 00010000
MAXI DOT 1 = xxx01xxx
Byte 11
Up to 0616 always = 10000000
From 0616
Default value = 10000001
XENON = xxxxxxx0
Byte 12 not possible always = 00010001
Byte 14
NBL 1 = xxxxxxx1
XENON 1 = xxxx1xxx
CORNER 1 = 1xxxxxxx
Byte 15
Default value = 01100100
MAXI DOT 1 = 1xxxxxxx
Byte 16
EB L 1 = xxxxxx1x
KL58D 1 = xxxxxxx1
Byte 17
XENON 1 = xxxxx1xx
AFL 1 = x111xxxx
Byte 20
HWS 1 = xxxxxx11
START 1 = xxx0xxxx
Byte 21
RS 1 = xx1xxxxx
Byte 22
WH 1 = xxxxxx1x
SIH 1 = xxxxx1xx
EFP 1 = xxxx1xxx
AH 1 = xx1xxxxx
AC 1 = 1xxxxxxx
Byte 25
Default value = 10000000
XENON 1 = xxxxx1xx
Byte 26
START 1 = 1xxxx111
Byte 27 to Byte 28
