Oudot vikakoodit 3.0TDI EDC17
Aloittaja msvahn, 05.01.12 - klo:19:58
msvahn
Skannasin läpi Audini ja askaruttamaan jäi mystiset koodit, joista en löytänyt tietoa. Kannattaakohan ne vain nollata ja katsoa tulevatko uudelleen? (boldasin ne)
VCDS Version: Release 11.11.1 (x64)
Data version: 20111209
Thursday,05,January,2012,19:11:02:21907
Chassis Type: 8T0
Scan: 01 03 05 07 08 09 0E 10 14 15 16 17 19 37 42 46 47 52 53 55
          56 62 72 77
VIN: WAUZZZ8K29Axxxxxx   Mileage: 103570km/64355miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CCWA)       Labels: 059-907-401-CAP.clb
   Part No SW: 8K2 907 401 A    HW: 8K1 907 401 A
   Component: 3.0TDI EDC17  H01 0006
   Revision: 15H01---
   Coding: 010C002C180F0118
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_ECM30TDI0118K2907401A 001006
   ROD: EV_ECM30TDI0118K2907401A.rod
   VCID: 2B5FEA12421E10C
5 Faults Found:
4695 - Function Restriction due to Received Malfunction Value
          U1113 00 [032] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
4698 - Function Restriction due to Received Malfunction Value
          U1113 00 [032] - -
4699 - Function Restriction due to Received Malfunction Value
          U1113 00 [032] - -
18660 - Unknown Error Code
          P151D 00 [032] - -
4483 - Function Restriction due to Received Malfunction Value
          U1113 00 [032] - -
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
   Part No SW: 8K0 907 379 AD    HW: 8K0 907 379 AD
   Component: ESP8 quattro  H04 0060
   Revision: --------    Serial number: --------------
   Coding: 1B4D00
   VCID: 7BFF1A52FAFE40C
1 Fault Found:
02214 - Tire Pressure Warning
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 137
                    Mileage: 103350 km
                    Time Indication: 0
                    Date: 2011.12.31
                    Time: 16:25:51
             Freeze Frame:
                    Hex Value: 0x5D00
                    Hex Value: 0x4006
                    Hex Value: 0x121A
                    Hex Value: 0x0EB7
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.clb
   Part No SW: 8K0 907 064 N    HW: 8K0 907 064 N
   Component: BCM2 1.1      H80 0141
   Revision: 00002001
   Coding: 030200
   VCID: 3B7FDA52BA7E80C
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H37 0060
   Subsystem 2 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Component: ELVAUDIB8  H36 0041
No fault code found.
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 N    HW: 4E0 035 729
   Component: Interfacebox    H43 5170
   Revision: 00000000    Serial number: 329H4087599474
   Coding: 0001001
   VCID: 448DA1AE0780FF4
   Part No: 8T0 919 609
   Component: E0380 BedienteilH08 0100
Address 08: Auto HVAC (J255)       Labels: Redir Fail!
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0140
   Revision: C1000000    Serial number: 0122.08.080374
   Coding: 36000000
   VCID: 72E13776ADB4014
Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
   Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000105834
   Coding: 260050914034AF210E01000300001D0D0F9C874800010141000000
   VCID: 3065FD7E6338734
   Subsystem 1 - Part No SW: 8K1 955 119 A    HW: 8T1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 140808  H06 0070
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
Address 0E: Media Player 1        Labels: 4E0-910-111.lbl
   Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
   Component: MP3-Changer     H43 0390
   Revision: 00043003    Serial number: AUZ5ZBH8554276
   Shop #: WSC 00000 000 00000
   VCID: 2A51EF1685E4094
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 E    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0020
   Revision: 11001001    Serial number: 52830822701671
   Coding: 100003
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8K0 907 364     HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H08 0052
   Revision: 00000000    Serial number: 16070802320001
   Coding: 010181
   Shop #: WSC 36668 133 71950
   VCID: F0E5BD7E23B8B34
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0038JD1A3RDB
   Coding: 30343434363030303030554A304C384B3053
   ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
   VCID: 3C7DD94EB770874
   Serial number: 6334MSME3F204E41G
   Serial number: 6344MSME3F542C68T
   Serial number: 6352QSME14041E36A
   Serial number: 6362QSME0B0327102
   Serial number: 63732SME64023718U
   Serial number: 63832SME7D010F1E8
Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
   Part No SW: 8K0 953 568 F    HW: 8K0 953 568 F
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90304HHI00059
   Coding: 000017
   VCID: 3D7BD44AA46A8EC
   Component: E221 - MFL  H02 0003
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 930 C    HW: 8K0 920 930 C
   Component: KOMBIINSTR.   H17 0224
   Revision: 00000000    Serial number: 9E253AW88
   Coding: 0F04110013000008000000
   VCID: 2D5BE40A740A1EC
Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
   Part No SW: 8T0 907 468 K    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0094
   Revision: 4EB40045    Serial number: 4500E0880780BE
   Coding: 000303
   VCID: 4993B09AE0A222C
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
   Part No SW: 4E0 910 888 E    HW: 4E0 919 887 M
   Component: MNS ECE         H51 1050
   Revision: 00000000    Serial number: 333HS087605355
   Shop #: WSC 00477 128 52244
   VCID: 3065FD7EA338734
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 B    HW: 8K0 959 793
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000007606045
   Coding: 011C02204000410001
   VCID: 3F87AE42AE669CC
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0113948973
   Coding: 0100062020390440012002
Address 47: Sound System (J525)       Labels: 8T0-035-223-BAM.clb
   Part No SW: 8T0 035 223 AE    HW: 8T0 035 223 R
   Component: DSP Basic     H08 0300
   Revision: S2600000
   Coding: 010101
   VCID: 71E3387AA8B23AC
Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
   Part No SW: 8K0 959 792 B    HW: 8K0 959 792
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000007599078
   VCID: 3E79D346A96C954
Address 53: Parking Brake (J540)       Labels: 8K0-907-801.clb
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 10000000082774
   VCID: 3163F87A68327AC
Address 55: Xenon Range        Labels: 8K0-907-357.clb
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Revision: 00000001    Serial number:
   Coding: 0000005
   Shop #: WSC 06334 000 00000
   VCID: 346DF16E57204F4
Address 56: Radio        Labels: 4E0-910-541.lbl
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 336HR087591050
   Coding: 0000001
   VCID: 2E59E306B90C654
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795     HW: 8K0 959 795
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000007629574
   Coding: 010C02204000210001
   VCID: FF076E426EE6DCC
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
   Part No SW: 8K0 959 794     HW: 8K0 959 795
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000007619005
   VCID: FEF9934669ECD54
Address 77: Telephone        Labels: 4E0-910-336.lbl
   Part No SW: 4E0 910 336 M    HW: 4E0 862 335
   Component: Handyvorb2      H20 1130
   Revision: 00000000    Serial number: 00000005251250
   Coding: 0010910
   VCID: 2C5DE90E8F10174
End   ---------------------------------------------------------------------
Nykykalusto
