T6 abs,esc ja neliveto ongelma
Aloittaja T64motion, 18.12.23 - klo:10:57
T64motion
Moro, t6 portterissa tovin palanut abs ja esc valo ja lumien tultua huomasin ettei nelivetokaan toimi.
Luetin vikakoodit vcds:llä ja vaihdoin abs anturin joka antoi vikakoodia. Sillä sammui abs valo mutta esc palaa edelleen eikä neliveto toimi. Välillä valittaa myös start/stop erroria, jos sillä nyt mitään merkitystä on muihin vikoihin.
Tuollainen raportti tuli vikakoodeista:
2 Faults Found: 4197-Rear Left Wheel Speed Sensor C101C 14 [000010001- Open or Short to Ground Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 9 Reset counter: 201 Mileage: 284363 km Date: 2091.14.22 Time: 17:29:08
8269- Databus U1121 00 [10001001]- Missing Message [ACAN: mAllrad_1 frame timeout] MIL ON-Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 158 Mileage: 284363 km Date: 2091.14.22 Time: 17:29:08
25126 - Implausible Data Received from ESP Control Module U0416 00 [00101111] -- Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 3 Mileage: 284363 km Date: 2091.01.22 Time: 17:29:01
2 Faults Found: 31343-Control Module for All Wheel Drive Clutch U0114 00 [00101111] - No Communication Confirmed- Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 15 Mileage: 84363 km Date: 2091.01.22 Time: 17:29:02
Engine RPM: 971.50 /min Normed load value: 22.4 % Vehicle speed: 0 km/h Coolant temperature: 30 °C Intake air temperature: 5 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 11.429 V Unlearning counter according OBD: 40 Air mass at air mass meter 1: 46.8 kg/h Standardized air flow ratio: 1.105 counts Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 26.25 % Throttl.valve adapt. 1 bank 1: posit feedback- Actual value: 0.00 % Index of engine target mode: 0 Charge air pressure: specified value: 0.988 bar Absolute intake pressure: 99 kPa abs Mean injection quantity: 5 mg/stroke Index of current engine mode: 0 Index of next requested engine mode: 0
Jacce75
Lainaa2 Faults Found: 31343-Control Module for All Wheel Drive Clutch U0114 00 [00101111] - No Communication Confirmed- Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 15 Mileage: 84363 km Date: 2091.01.22 Time: 17:29:02
Tuo viittaa vialliseen haldex ecuun tai sitten se ei saa jostain syystä virtaa. Kannattaa ainkain aluksi tarkistaa sulakkeet.
http://www.vagtech.fi
040-7049099
keskustelu.vagtech.fi
nikotinnf
Onko vika löytynyt, tänään tuli sama
