Kirjoittaja Aihe: Sulakkeet  (Luettu 2132 kertaa)
Poissa heppi
  • Jäsen
    • Profiili
Sulakkeet
« : 28.08.18 - klo:22:08 »
Sisätila sulakkeet:
No.   Current Flow Diagram designation Nominal value   Function/component Terminal
1   Fuse 1 on fuse holder C -SC1- -   Not assigned 15
2   Fuse 2 on fuse holder C -SC2- -   Not assigned 15
3   Fuse 3 on fuse holder C -SC3- -   Not assigned 15
4   Fuse 4 on fuse holder C -SC4- 10A   DC/AC converter with socket, 12 V-230 V -U13- 15
         Voltage stabiliser -J532- 15
         Starter relay 1 -J906-1
          Starter relay 2 -J907-1 15
5   Fuse 5 on fuse holder C -SC5- 10A   Electronically controlled damping control unit -J250- 15
6   Fuse 6 on fuse holder C -SC6- -   Not assigned 15
7   Fuse 7 on fuse holder C -SC7- -   Not assigned 15
8   Fuse 8 on fuse holder C -SC8- -   Not assigned 15
9   Fuse 9 on fuse holder C -SC9- 7.5A   Front passenger side airbag deactivated warning lamp -K145- 15
          Airbag​ control​ unit​ -J234- 15
10   Fuse 10 on fuse holder C -SC10- 5A   Taxi meter -G41- 15
         Mirror taxi meter -G511- 15
          Control unit for taxi alarm remote control -J601- 15
11   Fuse 11 on fuse holder C -SC11- 10A   All-wheel drive control unit -J492- 15
12   Fuse 12 on fuse holder C -SC12- 10A   Left gas discharge light -L13- 15
13   Fuse 13 on fuse holder C -SC13- 5A   Electromechanical parking brake button -E538- 15
         Oil level and oil temperature sender -G266- 15
         Reversing light switch -F4- 15
         Operating unit in front of centre console -E461- 15
         High-pressure sender -G65- 15
         Parking aid control unit -J446- 15
         Interior mirror -EX5- 15
14   Fuse 14 on fuse holder C -SC14- 7.5A   Lighting switch -E1- 15
         Trailer detector control unit -J345- 15
         Control​ unit​ for​ electromechanical​ parking​ brake -J540- 15
          ABS control unit -J104- 15
         Brake light switch -F- 15
         Power steering control unit -J500- 15
         Engine control unit -J623- 15
         Data bus diagnostic interface -J533- 15
          Control unit in dash panel insert -J285- 15
15   Fuse 15 on fuse holder C -SC15- 10A   Auxiliary heater operation relay -J485- 15
         Diagnostic connection -U31- 15
          Left headlight -MX1- , not Xenon 15
         Right​ headlight -MX2- , not Xenon  15
         Control unit for bend lighting and headlight range control​ -J745- 15
         Switch and instrument illumination regulator -E20- 15
          Air mass meter -G70- 15
16   Fuse 16 on fuse holder C -SC16- 10A   Right gas discharge bulb -L14- 15
17   Fuse 17 on fuse holder C -SC17- 5A   Mobile telephone operating electronics control unit -J412- 30
18   Fuse 18 on fuse holder C -SC18- 7.5A   Control unit for taxi alarm remote control -J601- 30
         Data transmission control unit -J753- 30
19   Fuse 19 on fuse holder C -SC19- -   Not assigned
20   Fuse 20 on fuse holder C -SC20- 5A   ABS control unit -J104- 30
21   Fuse 21 on fuse holder C -SC21- 5A   2nd heat exchanger switch-off valve -N317- 30
22   Fuse 22 on fuse holder C -SC22- 7.5A   Rain and light sensor -G397- 30
         Diagnostic connection -U31- 30
         Reversing camera system control unit -J772- 30
         Lighting switch -E1- 30
23   Fuse 23 on fuse holder C -SC23- 7.5A   Selector lever sensors control unit -J587- 30
         Electromechanical parking brake button -E538- 30
         Climatronic control unit -J255- 30
         Air​ conditioning​ system​ control​ unit​ -J301- 30
         Operating​ and​ display​ unit​ for​ rear​ air​ conditioning​ system -E265- 30
          Rear blower regulation sensor -G463- 30
          Remote control receiver for auxiliary coolant heater -R149- 30
24   Fuse 24 on fuse holder C -SC24- 7.5A   Entry​ and​ start​ authorisation​ control​ unit​ -J518- 30
25   Fuse 25 on fuse holder C -SC25- 7.5A   Mechatronic unit for dual clutch gearbox -J743- 15
          Selector lever sensors control unit -J587- 15
26   Fuse 26 on fuse holder C -SC26- 5A   Air quality sensor -G238- 15
27   Fuse 27 on fuse holder C -SC27- -   Not assigned
28   Fuse 28 on fuse holder C -SC28- 15A   Rear window wiper motor -V12- 75
29   Fuse 29 on fuse holder C -SC29- 30A   12 V socket -U5- 75
         12 V socket 3 -U19- 75
         Blocking diode -J29- 75
30   Fuse 30 on fuse holder C -SC30- 30A   Cigarette lighter -U1- 75
         12 V socket 2 -U18- 75
         Onboard supply control unit -J519- (T52c/21) 75
          # Terminal 75 diagnosis feedback
31   Fuse 31 on fuse holder C -SC31- -   Not assigned 75
32   Fuse 32 on fuse holder C -SC32- -   Not assigned 75
33   Fuse 33 on fuse holder C -SC33- -   Not assigned 75
34   Fuse 34 on fuse holder C -SC34- -   Not assigned 75
35   Fuse 35 on fuse holder C -SC35- -   Not assigned 75
36   Fuse 36 on fuse holder C -SC36- 30A   Control​ unit​ for​ electromechanical​ parking​ brake -J540- 30
37   Fuse 37 on fuse holder C -SC37- 25A   Sliding sunroof control unit -J245- 30
38   Fuse 38 on fuse holder C -SC38- 30A   Sunroof roller blind control unit -J394- 30
39   Fuse 39 on fuse holder C -SC39- 7.5A   Steering column electronics control unit -J527- 30
40   Fuse 40 on fuse holder C -SC40- 5A   Multimedia system control unit -J650- 30
41   Fuse 41 on fuse holder C -SC41- 5A   Dash panel insert -K- 30
42   Fuse 42 on fuse holder C -SC42- 15A   Electronically controlled damping control unit -J250- 30
43   Fuse 43 on fuse holder C -SC43- 30A   Driver seat lumbar support adjustment switch -E176- 30
          Front passenger seat lumbar support adjustment switch -E177- 30
44   Fuse 44 on fuse holder C -SC44- 25A   Fresh air blower relay -J13- 30
          Heated rear window relay -J9- 30
45   Fuse 45 on fuse holder C -SC45- 30A   Front passenger door control unit -J387- 30
          Rear right sliding door control unit -J871- 30
46   Fuse 46 on fuse holder C -SC46- 30A   Driver door control unit -J386- 30
          Rear left sliding door control unit -J870- 30
47   Fuse 47 on fuse holder C -SC47- 10A   Taxi meter -G41- 30
          Mirror taxi meter -G511- 30
          Front interior light button -E326- 30
          Taxi sign switch -E138- 30
          Taxi alarm active button -E485- 30
48   Fuse 48 on fuse holder C -SC48- 15A   Anti-theft alarm system horn -H8- 30
          Interior monitoring sensor -G273- 30
          Onboard supply control unit -J519- (T52c/1) 30
          # Terminal 30, Anti-theft alarm supply
49   Fuse 49 on fuse holder C -SC49- 30A   Control​ unit​ for​ electromechanical​ parking​ brake -J540- 30
50   Fuse 50 on fuse holder C -SC50- 30A   Onboard supply control unit -J519- , (T52b/1) 30
          # Terminal 30, Central locking supply
51   Fuse 51 on fuse holder C -SC51- 30A   Heated front seats control unit -J774- 30
52   Fuse 52 on fuse holder C -SC52- 30A   Rear air recirculation blower -V242- 30
53   Fuse 53 on fuse holder C -SC53- 30A   DC/AC converter with socket, 12 V-230 V -U13- 30
54   Fuse 54 on fuse holder C -SC54- 10A   Electronic steering column lock control unit -J764- 30
55   Fuse 55 on fuse holder C -SC55- 25A   Trailer voltage supply relay -J941- 30
56   Fuse 56 on fuse holder C -SC56- 30A   Trailer detector control unit -J345- 30
57   Fuse 57 on fuse holder C -SC57- 10A   Two-way radio unit -R8- 30
58   Fuse 58 on fuse holder C -SC58- 25A   Special vehicle control unit -J608- 30
1 Only models with start/stop system
2 Only models with no start/stop system
Moottori:
F1 - Fuse 1 on fuse holder B -SB1- 30A   Voltage stabiliser -J532- 30
F2 - Fuse​ 2 on​ fuse​ holder B -SB2- 30A   Onboard supply control unit -J519- , (T52b/42) 30
          # terminal 30 power
F3 - Fuse 3 on fuse holder B -SB3- 30A   ABS control unit -J104- 30
F4 - Fuse 4 on fuse holder B -SB4- 30A   Onboard supply control unit -J519- (T52a/1) 30
          # terminal 30, left light supply
F5 - Fuse 5 fuse holder B -SB5- 5A   Onboard supply control unit -J519- , (T52a/24) 30
         # terminal 30, reference
          Battery​ monitor​ control​ unit​ -J367- 30
F6 - Fuse 6 on fuse holder B -SB6- 30A   Onboard supply control unit -J519- (T52c/42) 30
          # terminal 30, right light supply
F7 - Fuse 7 on fuse holder B -SB7- 25A   Dual tone horn relay -J4- 30
          Heated windscreen relay -J47- 30
F8 - Fuse 8 on fuse holder B -SB8- 30A   Digital sound package amplifier -R184- 30
F9 - Fuse 9 on fuse holder B -S9- 20A   Control​ unit​ with​ display​ for​ radio​ and​ navigation -J503-4 30
F10 - Fuse 10 on fuse holder B -SB10- 30A   Engine control unit -J623- 87
F11 - Fuse 11 on fuse holder B -SB11- 5A   Data bus diagnostic interface -J533- 30
F12 - Fuse 12 on fuse holder B -SB12- 15A   Mechatronic unit for dual clutch gearbox -J743- 30
F13 - Fuse 13 on fuse holder -SB13- 5A   Engine control unit -J623- 30
          Main relay -J271- 30
          Fuse 14 on fuse holder B -SB14- 87
          Fuse 16 on fuse holder B -SB16- 87
          Fuse 18 on fuse holder B -SB18- 87
          Fuse 20 on fuse holder B -SB20- 87
          Fuse 23 on fuse holder B -SB23- 87
          Fuse 24 on fuse holder B -SB24- 87
F14 - Fuse 14 on fuse holder B -SB14- 10A   Reducing agent pump -V437-1 87
      30A  Ignition coil 1 with output stage -N70- 87
         Ignition coil 2 with output stage -N127- 87
         Ignition coil 3 with output stage -N291- 87
         Ignition coil 4 with output stage -N292- 87
F15 - Fuse 15 on fuse holder B -SB15- -   Not assigned 30
F16 - Fuse 16 on fuse holder B -SB16- 30A   Reducing-agent heater control unit -J891-1 87
      15A  Lambda probe -G39- 87
         Lambda probe after catalytic converter -G130- 87
         Magnetic clutch for supercharger -N421- 87
F17 - Fuse 17 on fuse holder B -SB17- 15A   Fuel pressure regulating valve -N276- 87
F18 - Fuse 18 on fuse holder B -SB18- 30A   Fuel pump control unit -J538- 87
F19 - Fuse 19 on fuse holder B -SB19- 30A   Wiper motor control unit -J400- 87
F20 - Fuse 20 on fuse holder B -SB20- 15A   Additional coolant pump relay -J496-2 87
         Lambda probe -G39-1 87
         NOx sender control unit -J583-1 87
         Air mass meter -G70-1 87
F21 - Fuse 21 on fuse holder B -SB21- 20A   Auxiliary heater control unit -J364- 30
F22 - Fuse 22 on fuse holder B -SB22- 20A   Headlight washer system relay -J39- 30
F23 - Fuse 23 on fuse holder B -SB23- 15A   Charge​ pressure​ control​ solenoid​ valve -N75-1 87
         Crankcase​ breather​ heater​ element -N79-1 87
         Automatic​ glow​ period​ control​ unit -J179-1 87
         Exhaust gas recirculation cooler changeover valve -N345-1 87
         Fuel metering valve -N290-1 87
         Fuel pressure regulating valve -N276-1 87
         Coolant circulation pump 2 -V178-1 87
         Clutch position sender -G476- 87
F24 - Fuse 24 on fuse holder B -SB24- 10A   Engine component current supply relay -J757-2 , 3 87
         #Fuse 17 on fuse holder B -SB17-2
         #Fuse 28 on fuse holder B -SB28-1
         Radiator fan control unit -J293- 87
         Turbocharger air recirculation valve -N249- 87
         Activated charcoal filter system solenoid valve 1 -N80- 87
         Camshaft​ control​ valve​ 1 -N205- 87
         Charge​ pressure​ control​ solenoid​ valve -N75-2 87
         Low heat output relay -J359- 87
         High heat output relay -J360- 87
F25 - Fuse 25 on fuse holder B -SB25- 40A   ABS control unit -J104- 30
F26 - Fuse 26 on fuse holder B -SB26- 40A   Fresh air blower control unit -J126- 30
         Low heat output relay -J359- 30
F27 - Fuse 27 on fuse holder B -SB27- 50A   Terminal 15 voltage supply relay 2 -J681- 30
F28 - Fuse 28 on fuse holder B -SB28- 50A   Automatic glow period control unit -J179- 30, (87)
F29 - Fuse 29 on fuse holder B -SB29- 40A   Fuse 17 on fuse holder C -SC17- 30
         Fuse 18 on fuse holder C -SC18- 30
         Fuse 37 on fuse holder C -SC37- 30
         Fuse 39 on fuse holder C -SC39- 30
         Fuse 40 on fuse holder C -SC40- 30
         Fuse 41 on fuse holder C -SC41- 30
          Fuse 58 on fuse holder C -SC58- 30
F30 - Fuse 30 on fuse holder B -SB30- 50A   Terminal​ 75​ voltage​ supply​ relay​ 1 -J680-
Autodoc.FI
www.Euvaraosat.fi
Custom-Garage.fi
