Ongelmia T5 kanssa
Aloittaja V3lmu, 12.11.17 - klo:20:26
V3lmu
Hei!
Tutkin erästä T5:sta vm.10 , jossa alkuoireena oli mm. takavalojen palamattomuus, etuikkunoiden toimimattomuus ja takaikkunan lämmityksen toimimattomuus.
tässäpä ensimmäinen logi:
Sunday,12,November,2017,15:52:49:57660
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
[url=http://www.Ross-Tech.com]www.Ross-Tech.com[/url]
Dealer/Shop Name: J.P
VIN: WV1ZZZ7HZAH207953   License Plate:
Mileage: 247860km-154013mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 15 17 18 19 25 56 69 0B
VIN: WV1ZZZ7HZAH207953   Mileage: 247860km-154013miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: Cannot be reached 1100
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CH    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H31 9970
   Revision: 26H31---    Serial number: 00000000000000
   Coding: 0119401A232400080000
   Shop #: WSC 41154 000 1048576
   ASAM Dataset: EV_ECM20TDI01103L906022CH 002013
   ROD: EV_ECM20TDI01103L906022CH_002.rod
   VCID: 6DE98AC9BC70C22E51-8038
3 Faults Found:
4481 - Cruise Control Switch (E45)
          P0568 00 [047] - Implausible Signal
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 247282 km
                    Date: 2017.11.09
                    Time: 17:35:54
                    Engine speed: 860.50 /min
                    Normed load value: 20.4 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 56 °C
                    Intake air temperature: 25 °C
                    Ambient air pressure: 960 mbar
                    Voltage terminal 30: 14.260 V
                    Unlearning counter according OBD: 40
                    Cruise Control System (CCS): switch position-Bit 0: 192
                    Cruise Control System (CCS): status-Bit 0: 200
                    Cruise control switch-off: irreversible-Bit 0: 255
                    Cruise control switch-off: reversible-Bit 0: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Engine control module reset status-Bit 0: 0
                    Engine control module reset status-Bit 8: 0
                    Cruise control switch-off: irreversible w. brake intervention-Bit 0: 0
4482 - Function Restriction due to Implausible Message(s)
          U1112 00 [047] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 19
                    Mileage: 246506 km
                    Date: 2017.10.27
                    Time: 02:27:37
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Coolant temperature: 51 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 11.880 V
9531 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0105 00 [032] - Malfunction
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 247068 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Coolant temperature: 17 °C
                    Intake air temperature: 12 °C
                    Ambient air pressure: 970 mbar
                    Voltage terminal 30: 12.280 V
                    Unlearning counter according OBD: 32
                    Charge air pressure: actual value: 970.0 hPa
                    Intake air pressure sensor after air cleaner: raw value: 1150 hPa
                    Engine status: COENG_STANDBY
                    Outside air temperature: 13.5 °C
                    Particle filter: difference pressure: -2 hPa
                    Sensor for particle filter differential press: raw value: 5 hPa
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----)       Labels:. 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 E    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0103
   Revision: 00H43001
   Coding: 708724AD89A40E9C24AB9176696110
   Shop #: WSC 02736 790 49152
   VCID: 345F5FAD97DA53E65E-8060
No fault code found.
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 7E5 907 047 Q    HW: 7E5 907 047 Q
   Component: Climatic-T5   H10 0101
   Revision: 00004001
   Coding: 0000000002
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ClimaticT5 A01002
   ROD: EV_ClimaT5Basis.rod
   VCID: 3D497A89AC9092AEA1-8068
1 Fault Found:
13701440 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 100
                    Reset counter: 114
                    Mileage: 246506 km
                    Date: 2017.10.27
                    Time: 02:28:35
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 087     HW: 7H0 937 087
   Component: BCM T5GP      H24 0027
   Revision: BO024001    Serial number: 9815A252090164
   Coding: 0000000000000000000000000000000000000000000000000000
   Shop #: WSC 02759 790 00000
   VCID: 71D196B9A84826CE75-8024
   Subsystem 1 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 0301
   Serial number: --------------------
   Coding: 000000
   Subsystem 2 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 0305
   Coding: 000000
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 246506 km
                    Time Indication: 0
                    Date: 2012.03.19
                    Time: 02:26:41
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 7E0 959 655 A    HW: 7E0 959 655 A
   Component: VW10Airbag00N H05 0011
   Revision: --------    Serial number: 003E50006ZZC
   Coding: 00000000000000000000000000000000304E
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 345F5FAD9FDA53E65E-8060
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 7E0 920 860 A    HW: 7E0 920 860 A
   Component: KOMBI         H15 0111
   Coding: 160A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
   ROD: EV_Kombi_UDS_VDD_RM09_004_VN35.rod
   VCID: 267BB5E559063176D0-8072
Address 18: Aux. Heat
Cannot be reached
Address 19: CAN Gateway (J533)       Labels:. 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 0027
   Coding: 042200
   VCID: 70D793BDA3422FC67A-8024
2 Faults Found:
01207 - Control Module for Auxiliary Heater (J364)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 101
                    Mileage: 246506 km
                    Time Indication: 0
                    Date: 2012.03.19
                    Time: 02:27:08
02830 - CAN-Extended Separator for Driver Assistance Systems
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 146
                    Time Indication: 0
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H15 0111
   Serial number:
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 7E0 035 156     HW: 7E0 035 156
   Component: Radio         H21 0058
   Revision: R0000000    Serial number: VWZAZ1I9801835
   Coding: 0000020001
   Shop #: WSC 02736 790 00000
   VCID: 60F7E3FD73A29F46EA-8034
Address 69: Trailer        Labels: RETROFIT69.lbl
   Part No SW: 5F0 05V 020 2    HW: 5F0 05V 020 2
   Component: TOWBARMODULE ECS    0010
   Coding: 0000001
   Shop #: WSC 00000 000 00000
   VCID: 2A6341D5851E1516F4-807E
End-------------------------(Elapsed Time: 02:41)--------------------------
Huomasin, että T5 oli hävittänyt kohdan 09: Cent. Elect. kaikki koodaukset...
Autoon koodattiin kaikki mahdolliset/tarvittavat ominaisuudet päälle. Ylhäältä edeltä mainitut viat korjaantui, mutta...
Keskuslukitus ei lähtenyt toimimaan avaimesta ja tämän lisäksi kartturin puolen ovi ja takaluukku jäivät "takalukkoon".
Yritin tätä ainutta avainta sovittaa kyseiseen autoon, mutta kyseinen toimenpide ei onnistu, jos joku/jotkut ovet ovat lukossa. Eivätkä ohjekirjankaan ohjeet auttaneet tähän ongelmaan. Enkä löytänyt internetistä selvää ohjetta tälle toimenpiteelle ja tälle kyseiselle automallille.
Hassuahan tässä on se, että välillä tuli vikakoodeja, ettei avainta ole koodattu kyseiseen autoon, mutta silti tämä auto käynnistyi normaalisti ja autolla pystyi ajamaan.  :o
Lainaaoliko tämä nyt sitä autojen "pyhällä hengellä" kulkemista? - tiedä häntä :D
1 Fault Found:
01179 - Incorrect Key Programming
            000 -  -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 114
                    Time Indication: 0
Mutta itse kysymyksiin:
- Miten nämä kyseiset ovet saadaan takalukosta auki?
- Miten T5 avaimet sovitetaan kyseiseen autoon? Vaatiiko toimenpide muitakin ohjelmia kuin vcds?
Autojen diagnostiikkaa, koodausta yms. @ Oulu/Vieremä
Oiskohan joku isompi sulake konehuoneen puolelta palanut?
Tälläinen ohje voisi toimia kaken ohjelmointiin:
- Avain virtalukoon ja viiden sekunnin sisään virrat päälle ja pois
- Virrat päälle ja 15 sekunnin kuluessa lukitse ovet kuskin oven lukitusnappulasta
- 30 sekunnin sisään paina kaken avaa- tai suljenäppäintä kahdesti
Ajonesto ja keskuslukituksen toiminta ovat kaksi täysin toisistaan riippumatonta toimintoa. Ajonesto on kytköksissä avaimen sisällä olevaan pieneen lasiputkiloon ja kaukosäätimen toiminto taas kaukosäätimen elektroniikkaan ja sen koodiin.
V3lmu
LainaaOiskohan joku isompi sulake konehuoneen puolelta palanut?
Autosta tarkistettiin kaikki lattasulakkeet, mutta ei löytynyt palaneita. Voidaan tarkistaa uudelleen.
LainaaTälläinen ohje voisi toimia kaken ohjelmointiin:
Testataan! :)
LainaaAjonesto ja keskuslukituksen toiminta ovat kaksi täysin toisistaan riippumatonta toimintoa. Ajonesto on kytköksissä avaimen sisällä olevaan pieneen lasiputkiloon ja kaukosäätimen toiminto taas kaukosäätimen elektroniikkaan ja sen koodiin.
VCDS ilmoitti, kun yritin sopeuttaa avainta, niin ruutuun tuli ikkuna, jossa luki suurinpiirtein näin englanniksi vapaalla suomennoksella. "Avaimen ohjelmointi ei onnistu. Varmistathan, että autosta on kaikki mahdolliset ovet avoinna." Niin tästä tuli se epäillys  ???
Onko nämä sulkakkeet tarkistettu? Eka taitaa olla laturille ja loput sitten muille laitteille. Noista jos yksi palaa, lakkaa kerralla useampi laite kerralla toimimasta.
V3lmu
Ongelma on ratkennut. Eikä valitettavasti johtunut palaneesta sulakkeesta..  :(
Autoon on jouduttu ostamaan uusi BMC- ohjausmoduuli.
Nyt kaikki toiminnot pelaa, niin kuin ennenkin.
Loppu hyvin, kaikki hyvin  :)
