Superb uusi akku?
Aloittaja k.t.m, 06.09.15 - klo:20:37
k.t.m
4-vuotiaan 1.6TDI Superb Greenlinen akku ilmeisesti uusissa, pari kertaa heittänyt akun kuvaa tiskiin joista jäänyt ao. vikakoodit. Motonetissä Bosch S6011/S5A11 80Ah 209,90â,¬, vai olisiko parempia suosituksista uudesta AGM akusta?
Kiitokset jo etukäteen vinkeistä niin vikakoodin kuin akunkin suhteen.,
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 P    HW: 1K0 937 087 P
   Component: BCM PQ35  H+  104 0615
   Revision: 00104 AE
   Coding: 40010AB8E00508C040080080310089E4437900AE632185605C81C7000041
   Shop #: WSC 33361 790 00999
   VCID: 3E55134EA9AE49CE6F-806A
   Subsystem 1 - Part No: 3T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 02021  26  0602
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 040211 05  54  0403
   Coding: 0730ED
1 Fault Found:
00907 - Intervention load Management
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 121559 km
                    Time Indication: 0
                    Date: 2015.09.06
                    Time: 18:20:00
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.20 V
                        ON
                        ON
                        Term 50 On
                        OFF
                        OFF
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 3T1 920 841 H    HW: 3T1 920 841 H
   Component: KOMBI         H20 0420
   Serial number: 00000000000000
   Coding: 111F01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
   VCID: 38590556838A77FEA5-806C
1 Fault Found:
13639427 - Please Check Fault Codes in Engine Control Module
          U101F 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 121559 km
                    Date: 2015.09.06
                    Time: 18:22:10
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H35 0614
   Serial number: 300111F1000971
   Coding: 030B185A
   VCID: 71CFF872A870E6B6A2-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
2 Faults Found:
02252 - Generator
            003 - Mechanical Failure - Intermittent
             Freeze Frame:
                    Fault Status: 00100011
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 92
                    Mileage: 120711 km
                    Time Indication: 0
                    Date: 2015.08.28
                    Time: 11:44:16
02252 - Generator
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 106
                    Mileage: 121434 km
                    Time Indication: 0
                    Date: 2015.09.06
                    Time: 12:04:12
Tesla Model Y LR -23 Quicksilver
Å koda Superb Combi Style 1.4 TSI ACT -17
ex-vag: Å koda Superb Combi 1.6 TDI Ambition GreenLine -11
Volkswagen Golf V Variant 1.4 TSI 118kw -08
Å koda Octavia Combi 1.9 TDI 77kW -05
Å koda Octavia Combi 1.8T 110kW -03
Eikös noissa vikakoodeissa puhuta viallisesta laturista? Se ei lataa akkua kunnolla. Selvittele tuo ensin.
k.t.m
#2
Lainaus käyttäjältä: Jultsu - 06.09.15 - klo:21:42
Generator Status - Electrical pomppii OK ja Not OK välillä joten näyttäisi tosiaan kallistuvan laturin/jännitteensäätäjän suuntaan. Katsotaan mitä huomenna huollossa löytyy.
k.t.m
Lainaus käyttäjältä: k.t.m - 07.09.15 - klo:12:58
Laturi vaihtoon eikä varaosaa suoraan hyllyssä joten matka jatkuu vakuutusyhtiön sijaisautolla.
Vaikka tietä nähnytkin 4,5v ja 120tkm ei tuon vielä pitäisi tiensä päässä olla. Saa nähdä tuleeko maahantuoja vastaan kustannuksissa.
duke7
Noita latureita tuntuu jostain syystä menevän juuri Superbeista. Joiltain tutuilta mennyt ja täältäkin löytyy useita tapauksia.
k.t.m
Lainaus käyttäjältä: k.t.m - 08.09.15 - klo:16:34
Uusi laturi ja kustannukset 852â,¬, maahantuojan vastaantulo 0%
-Huoltokirja aukoton
-ikää 4,5v
-ajettu 121tkm
ps. modet voisi vaihtaa aiheen laturiin viittaavaksi.
k.t.m
Lainaus käyttäjältä: k.t.m - 16.09.15 - klo:20:30
-ikää 4,5v
-ajettu 121tkm
Reklamoinnin ja uuden GW kyselyn seurauksena laturin osalta vastaantulo 70%, työnosuus jää itselle.
