Audi B8 (8K) keskusohjausyksikön J519 kytkennät
Aloittaja Late, 15.03.11 - klo:20:52
Late
Audi B8 keskusohjausyksikön J519 kytkennät
Kytkentä järjestys ohjainlaitteelle -J519
Liitin A (32-pin)
Pin 8: Warning lights button -E229
Pin 9: Redundancy contact, light switch
Pin 13: Valet parking button -E536
Pin 14: Rear roller blind switch -E149
Pin 17: Footwell lights, front -L151 / -L152
Pin 18: LIN 1 (light switch -E1)
Pin 26: Enable electric steering column lock
Pin 27: Valet parking button warning lamp -K159
Pin 28: Hazard warning light system warning lamp -K6
Pin 31: Switch search illumination terminal 58s
Liitin B (32-pin)
Pin 1: Switch search illumination terminal 58st
Pin 3: Bonnet contact switch -F266
Pin 5: Oil pressure switch for reduced oil pressure -F378
Pin 6: Brake fluid level warning contact -F34
Pin 9: Brake lining wear sender, front left -G34
Pin 10: Ambient temperature sensor -G17
Pin 13: Gear recognition switch -F208 (forward gear)
Pin 14: Front left seat temperature sender -G344 (not if seat ventilation fitted)
Pin 16: Terminal 15
Pin 17: Switch search illumination terminal 58s
Pin 19: Front right seat temperature sender -G345 (not if seat ventilation fitted)
Pin 21: Gear recognition switch -F208 (reverse gear)
Pin 25: General signal earth
Pin 27: Coolant shortage indicator sender -G32
Pin 28: Windscreen washer fluid level sender -G33
Pin 29: Horn relay -J413
Liitin C (16-pin)
Pin 2: LIN 1 (wiper motor control unit -J400, rain and light sensor -G397)
Pin 4: LIN 2 (Charisma switch module -E592, air quality sensor -G395, refrigerant pressure and temperature sender -G238, garage door opener control unit -J530, front left seat ventilation control unit -J799, front right seat ventilation control unit -J800)
Pin 14: CAN-Low
Pin 15: CAN-High
Liitin D (17-pin)
Pin 1: Servotronic solenoid valve -N119 (activation)
Pin 3: Windscreen washer pump -V5  (activation 2)
Pin 4: Windscreen washer pump -V5  (activation 1)
Pin 6: Headlight washer system pump -V11
Pin 8: AC compressor regulating valve -N280 (activation)
Pin 9: Interior light dimming
Pin 10: AC compressor regulating valve -N280 (earth)
Pin 12: Servotronic solenoid valve -N119 (earth)
Pin 14: Footwell lights, rear -W45/-W46
Pin 15: Terminal 30 - 2
Pin 16: Terminal 30 - 1
Pin 17: Terminal 30g - supply (interior light supply)
Liitin E (17-pin)
Pin 2: Daytime running lights and side lights bulb, left -L186 (halogen headlights) / Supply LED module, left, for daytime running lights and side lights -L176 (xenon headlights)
Pin 3: Dipped beam screen, left -V294 (xenon headlights)
Pin 4: Front right side marker light bulb -M34
Pin 5: Turn signal light bulb, front left -M5
Pin 6: Front left side marker light bulb -M33
Pin 8: Fog light bulb, left -L22
Pin 12: Main beam headlight bulb, left -M30 (halogen headlights) / Activation, LED module, left, for daytime running lights and side lights -L176 (xenon headlights)
Pin 15: Dipped beam headlight bulb, left -M29 (halogen headlights) / Left side gas-discharge lamp control unit -J343 (xenon headlights)
Pin 16: Terminal 30 left
Pin 17: Terminal 31 - 2
Liitin F (17-pin)
Pin 2: Main beam headlight bulb, right -M32 (halogen headlights) / Activation, LED module, right, for daytime running lights and side lights -L177 (xenon headlights)
Pin 7: Daylight driving light bulb, left -L174 (halogen headlights)
Pin 8: Fog light bulb, right -L23
Pin 9: Dipped beam screen, right -V295 (xenon headlights)
Pin 10: Turn signal light bulb, front right -M7
Pin 12: Daytime running lights and side lights bulb, right -L188 (halogen headlights) / Supply LED module, right, for daytime running lights and side lights -L177 (xenon headlights)
Pin 14: Daylight driving light bulb, front right -L175 (halogen headlights)
Pin 15: Dipped beam headlight bulb, right -M31 (halogen headlights) / Right side gas-discharge lamp control unit -J344 (xenon headlights)
Pin 16: Terminal 30 right
Pin 17: Terminal 31 - 1
Liitin G (6-pin)
Pin 1: Seat heating front left (heated driver's seat -Z6, heated driver's seat backrest -Z7); not if seat ventilation fitted)
Pin 3: Terminal 30 - 3
Pin 6: Seat heating front right (heated front passenger seat -Z8, heated front passenger seat backrest -Z9); not if seat ventilation fitted)
