Audi E-Tron
Aloittaja Flat, 08.12.09 - klo:14:03
Nyt kiireesti tilaamaan ettei lopu
LainaaAudi says it only plans to make 1000 units of its e-tron electric sports car and that it will almost certainly be priced at "above R8" levels when it goes on sale in 2012.
"There are always people who want to be first to own new technology," Achim Badstubner, Audi's head of exterior design told Autocar.
Koko juttu:http://www.autocar.co.uk/News/NewsArticle.aspx?AR=245681
Tässä ihan livekuvaa autosta. Mielenkiintoisia detaljeja nähtävissä.
http://www.telegraaf.nl/autotelegraaf/5535011/__Autovideo__Audi_e-Tron__.html?p=4,1
Hieman hitaat piuhat, malttia että videoa avautuu, ja pari mainosta alussa
Häkä
http://www.autoblog.com/2009/09/15/officially-official-frankfurt-2009-audi-e-tron-4-motors-1-b/
LainaaFour motors – two each at the front and rear axles – drive the wheels, making the concept car a true quattro. Producing 230 kW (313 hp) and 4,500 Nm (3,319.03 lb-ft) of torque, the two-seater accelerates from 0 to 100 km/h (0 – 62.14 mph) in 4.8 seconds, and from 60 to 120 km/h (37.28 – 74.56 mph) in 4.1 seconds. The lithium-ion battery provides a truly useable energy content of 42.4 kilowatt hours to enable a range of approximately 248 kilometers.
Siinä on menoa ja melskettä. 4500 newtonia kuulostaa ihan kohtuulliselta  ;D. Ã,,änipuoli ei välttämättä täytä urheiluauton kriteerejä. Vai kuuluuko semmoinen priusmainen vinkuna asiaan? Lämmitys on ihan mielenkiintoisesti hoidettu: lämpöpumpulla.
Pienempi e-tron concepti julkistetaan Detroitissa
babelfish käännös:
LainaaDebut newest version electric Audi in Detroit
• Compact and compromise electrically operated sports car
• Second electrically operated study model of Audi
• Low weight, high performances, useful radius of action
Audi present on of 11 up to 24 January North kept American international the car show (NAIAS) in Detroit just as compact (L/B/H 3,93/1,78/1,22 m.) as puristische sports car with entirely electric traction. For the thanks its low weight of 1,350 kilogrammes including to the application of the Audi Space frame and lithium ion batteries. file pleasure has been guaranteed by rear-wheel drive in combination with two elektromotoren which provide a common capacity of 150 kW/204 pk. The radius of action amounts to 250 km.
The Audi e-tron study model, which celebrates its world première in Detroit, are already at first sight a real sports car. That comes by its pronounced wigvorm in combination with the characteristic footing short for sports cars and striking 19 inches wheels. Approximately 399 kilogrammes weighing accumulator parcel with the associated terminal equipment have been placed by the rear axle. This contributes to the weight partitioning of 40:60, ideal for optimum file dynamics. The two elektromotoren both have been placed on the rear axle and have individual refrigeration. Together these engines provide a capacity of 150 kW/204 pk and a cross-belt of no less than 2,650 Nm. The performances are thus of high level. The sprint of 0-100 km/h lasts only 5.9 seconds and the tussensprint of 60-120 km/h confiscates only 5.1 seconds. Because the energy usage increases by increasing the speed bovenproportioneel, the top speed has been limited on 200 km/h. the strength of the elektromotoren can variably concerning the operated wheels be divided. This so-called torque-vectoring-systeem look with high-quality aluminium multilink in front and rear wheel framework, the sport-loving onderstelafstemming and the direct electromechanical control for an extremely dynamic and exactly kart-achtig behaviour.
tällä lisää:
http://www.autoexpress.co.uk/news/autoexpressnews/247231/audis_baby_r8_revealed.html
LainaaThe latest Audi e-tron has been confirmed as Audi R4 preview. Awesome!
Destined to slot between the R8 and TT ranges, the R4/e-tron is expected to get a range of powertrains, not just electric power. The all-electric version will be the halo car of the model line, but the gasoline-powered version (or versions) will undoubtedly be the volume sellers.
We already know about the latest e-tron's electric powertrain: 313 horsepower, 0-60 mph times of 5.9 seconds, top speed of 124 mph and a range of about 155 miles.
niin näitä pökäleitä on kenties tulossa joskus useampiakin versioita, tässä pienemmästä päästä
LainaaAudi has announced that it will partner with utilities E.ON and Stadtwerke München (SWM) as well as the Technical University of Munich (TUM) launch a field test program with its A1 e-tron in Munich, Germany by mid-2011. The automaker will supply 20 of the extended-range electric vehicles to its partners for an evaluation of the communication systems between the driver, vehicle and grid. Smartphone applications that let drivers monitor and manage charging will be a big part of the test program.
mun mielestä tuo on upea
LainaaThe four electric motors of the e-Tron have a total output of 313 hp. Even more impressive is the torque: 4,500 Nm. The empty weight of the electric sports car is 1,600 kg.
Kyllähän tuo vääntö vetää palavilla nesteillä pelleilevien mielen vakavaksi.
