Octavia vikakoodit
Aloittaja vagina, 19.11.16 - klo:14:47
vagina
Iso liuta vikakoodeja löytyi. Nollasin koodit minkä jälkeen 3tkm ajelua. Siltikin vielä jäi roppakaupalla.
Mitä nämä kaikki on?
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1Z0 907 044 AC    HW: 1Z0 907 044 AC
   Component: ClimatronicPQ35 120 0600
   Revision: 00120022    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 77F7D3C2069275FA8D-8022
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
            004 - No Signal/Communication - Intermittent
00716 - Air recirculation Flap Positioning Motor (V113)
            000 -  -  - Intermittent
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000005451888
   Coding: E98A8F130004140040110D000000000000087F065C000000000000000000
   Shop #: WSC 73430 790 00000
   VCID: 71E3EDDA68F62BCA43-8024
   Subsystem 1 - Part No: 1Z1 955 119 C  Labels: 1KX-955-119.CLB
  Component: Wischer 020108 022  0601
   Coding: 00055223
   Shop #: WSC 73430
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     181207 046  0204
   Coding: 00471077
   Shop #: WSC 73430
2 Faults Found:
02071 - Local Databus
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 125
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 12.70 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
01520 - Rain and Light Recognition Sensor (G397)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 125
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 12.70 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BN    HW: 1K0 953 549 BN
   Component: J0527           051 0100
   Coding: 0000042
   VCID: 7F073BE22EA24DBAC5-802A
5 Faults Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective
00576 - Terminal 15
            012 - Electrical Fault in Circuit - Intermittent
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 842 D    HW: 1Z0 920 842 D
   Component: KOMBIINSTRUMENT VD1 1612
   Revision: V1612036    Serial number: SKZ7Z0G4650433
   Coding: 0007102
   Shop #: WSC 50354 067 57207
   VCID: 387510FE4B0CBA8244-806C
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 129
                    Time Indication: 0
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       019 0040
   Revision: 00019000    Serial number: SKZ7Z3G0130131
   Coding: 0000400
   VCID: 2E5936A6B94874321E-807A
1 Fault Found:
00668 - Supply Voltage Terminal 30
            002 - Lower Limit Exceeded - Intermittent
jabajee
Eikäkö luinkin liian hätäisesti.
Tuntuisi väyläliikenteessä olevan häiriöitä auton eri purkkien välillä. Yksi alhaisen jännitteen koodikin siellä. Onko käynnistysongelmia, onko latausjännite ok, entäpä napajännite aamulla ennen auton käynnistämistä?
dwntime
Nuo steering wheel alla olevat vikakoodit pl. tuo wiper switch viittais virtalukon pohjaan. Mulla korjaantui nuo vikakoodit vaihtamalla se pohjaosa.
