T5 2.5tdi kytkin remppa ja vaihdettavat osat
Aloittaja t5velle, 25.02.21 - klo:09:47
t5velle
Friday,23,April,2021,22:07:08:28876
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64)
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZ7H117603   License Plate:
Mileage: 513950km-319353mi   Repair Order:
Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
          57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ7H117603   Mileage: 513950km-319353miles
Address 01: Engine        Labels: 070-906-016-BPC.clb
   Part No SW: 070 997 016 M    HW: 070 997 016 M
   Component: R5 2,5L EDC G000SG  0860
   Revision: --H05---    Serial number: VWZ7Z0G5243438
   Coding: 0001072
   Shop #: WSC 00000 256 01574
   VCID: 244738D7E4AB33AB87-5124
4 Faults Found:
004374 - Oxygen (Lambda) Sensor Heating; B1 S1
               P1116 - 000 - Open Circuit
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 513549 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Mass Air / Rev.: 0.0 mg/str
                    (no units): 1.00
                    (no units): 0.0
                    Bin. Bits: 11001001
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 000 - Open Circuit
             Freeze Frame:
                    Fault Status: 01110000
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 255
                    Mileage: 513549 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 13.15 V
                    Bin. Bits: 00101111
                    Temperature: 1.8C
                    Bin. Bits: 10110000
005660 - Glowplug for Cylinder 3 (Q12)
               P161C - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 513689 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 1176 /min
                    Speed: 1.0 km/h
                    Load: 8.2 %
                    Voltage: 13.30 V
                    Bin. Bits: 00101100
                    Temperature: 4.5C
                    Bin. Bits: 10110000
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 513690 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 38.0 km/h
                    Load: 0.0 %
                    Voltage: 13.15 V
                    Bin. Bits: 00101111
                    Temperature: 30.6C
                    Bin. Bits: 10110000
Readiness: 1 2 0 0 0
Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP.lbl
   Part No SW: 7H0 907 379 R    HW: 7H0 907 379 R
   Component: ESP MK25E1          0104
   Revision: 00H31001
   Coding: 0002604
   Shop #: WSC 02756 790 00000
   VCID: 4487985704EB13ABA7-50E8
No fault code found.
Address 08: Auto HVAC        Labels: Redir Fail!
   Part No: 7H0 820 045 AL
   Component: CLIMA/AC            0303
   Shop #: WSC 00000 000 00000
   VCID: 6FED07FB7DEDC0F32A-50E8
1 Fault Found:
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
   Part No: 7H0 937 049 T
   Component: BORDNETZ SGVER 1.0  2001
   Coding: 0000101
   VCID: 43859B4B01E514939E-5106
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 A
   Component: 3C AIRBAG VW51      0010
   Coding: 13123
   Shop #: WSC 02756
   VCID: 224B3ECFAEBF3D9BF5-50E8
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 861 E
   Component: KOMBI+WEGFAHRSP VDO V02
   Coding: 04113
   Shop #: WSC 00006
   VCID: 2E53DAFFEA6789FB61-5106
   WV2ZZZ7HZ7H117603     VWZ7Z0G5243438
1 Fault Found:
01304 - Radio
            49-00 - No Communications
Address 18: Aux. Heat        Labels: 7H0-819-008.clb
   Part No: 7H0 815 071 F
   Component: Standheizung        0209
   VCID: 2B55D3EB8975FCD346-5106
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 02756
   VCID: 70EF048730D3DF0B33-5106
1 Fault Found:
01304 - Radio
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: CXL Komfortgerᴠ    0004
   Coding: 00025
   Shop #: WSC 02756
   VCID: 326BCE8FFE5FAD1B05-4AE8
End-------------------------(Elapsed Time: 06:08)--------------------------
Address 01: DTCs cleared
t5velle
#91
Tollaset tiedot anto ja kaikki hävisi muutamaksi päiväks, jos joku ymmärtää kaiken niin saa kääntää selkosuomeksi 🙂
t5velle
Hehkut mitattu 0,7 vastus kaikissa sama, mitä toi sylinterin 1,2 ja 3 tarkottaa
t5velle
Nyt taas kauppaan mennessä palo moottorinvikavalo, mut tullessa ei. Eli antaa olla jos ei leimalla haittaa
Ei mene katsastuksesta läpi jos vikavalo palaa.
Soppa
Lainaus käyttäjältä: t5velle - 14.05.21 - klo:09:27
Jos auto rekisteröity ennen 1.1.2007, niin ei haittaa katsastusta
t5velle
Lainaus käyttäjältä: t5velle - 13.05.21 - klo:17:48
www.Ross-Tech.com
          57 6E 76 77 78 7D
   Coding: 0001072
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 513549 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    (no units): 1.00
                    (no units): 0.0
                    Bin. Bits: 11001001
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 255
                    Mileage: 513549 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 13.15 V
                    Bin. Bits: 00101111
                    Temperature: 1.8C
                    Bin. Bits: 10110000
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 513689 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 1176 /min
                    Speed: 1.0 km/h
                    Load: 8.2 %
                    Voltage: 13.30 V
                    Bin. Bits: 00101100
                    Temperature: 4.5C
                    Bin. Bits: 10110000
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 513690 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 38.0 km/h
                    Load: 0.0 %
                    Voltage: 13.15 V
                    Bin. Bits: 00101111
                    Temperature: 30.6C
                    Bin. Bits: 10110000
   Revision: 00H31001
   Coding: 0002604
1 Fault Found:
   Coding: 0000101
   Coding: 13123
   Shop #: WSC 02756
   Coding: 04113
   Shop #: WSC 00006
1 Fault Found:
01304 - Radio
   Coding: 00006
   Shop #: WSC 02756
1 Fault Found:
01304 - Radio
   Coding: 00025
   Shop #: WSC 02756
Ymmärtääkö joku mitä noi hehku viat on, vikavalot ei pala mutta silti antaa hehkuista ton saman
sprint
Johtojen liittimestä vissiin mittasit ohmit? Lähtikö ne heti liittimeltä omina johtoina jos voisi pihtivirtamittarilla mitata toimiiko yksikään.
Onko tuossa mallissa jokin jäähdytysnesteen kierrätyspumppu? Kun katselin sähkökaavioita niin jossain oli yhdistetty sulake hehkujen ohjauksen ja kierrätyspumpun välillä. Oli SD33 5A joka sijaitsi konehuoneen pienemmässä boksissa.
t5velle
Johdot menee nipussa, en tiiä mahtuisiko pihtivirtamittari väliin. Onhan siellä joku sähköinen vesipumppu, ku on webasto. Ei kait rele tai sulake voi olla rikki, sitten herjais kaikkia ja ilmottas varmaa moottori tai hehkuvalolla. Kaikki siis toimii oikein ja lähtee hyvin käymään, mutta testeri herjaa noi 1, 2 ja 3 sylinterin hehkut. Jos joku osais suomentaa mitä toi data tarkoittaa, kannattaako ne vaihtaa ennen talvea.
t5velle
Lainaus käyttäjältä: sprint - 20.03.21 - klo:08:08
Ei se hajoo kun ei lähe päälle kun paine alhaalla. Ilmankuivaimen vaihto juuri ennen täyttöä.
Missäs toi ilmankuivain on ja onko vaikee vaihtaa, huollossa sano et ei välttämättä oo helppo homma?
t5velle
Siis ilmastoinnista on kyse ku ei näköjää kopioinut koko juttua
sprint
Edestä katsottuna oikealla puolella ilmastoinnin lauhduttimessa. En muista pitikö vain maski ottaa irti vai mistä välistä näkyi.
t5velle
Epäili huollossa että ilmastoinnin kenno vuotaa (160â,¬ kenno), mahtuuko se tulee ylös jäähdyttäjän ja coolerin välistä keulaa purkamatta? Kattelin et saattaa onnistuu, mut onko kellään kokemuksia aiheesta? Kannattaako edes yrittää
sprint
Ohjeen mukaan etupuskurin irrotus pitäisi riittää.
t5velle
Ok, kattelin et riittää pelkkä maskin irrotus.
